rear seat belt
Old Aug 18, 2016 | 10:26 AM
Kewpie's Avatar
Default rear seat belt
What does the little buckle go to? It doesn't fit into any of the receivers.
Old Aug 18, 2016 | 11:04 AM
NBCat's Avatar
Look under the rear seat lower cushion for the anchor point.
Old Aug 18, 2016 | 11:37 AM
JagV8's Avatar
Should fit without any problem (as mine do)... maybe using the wrong one or the wrong way around?
Old Aug 18, 2016 | 11:54 AM
joycesjag's Avatar
Here's a picture that may help you out:
Oh BTW it was taken from this thread I did years ago:
https://www.jaguarforums.com/forum/i...atments-26363/
Old Aug 18, 2016 | 12:22 PM
Kewpie's Avatar
thanks for the info
Old Aug 19, 2016 | 11:56 AM
clubairth1's Avatar
Community Influencer
Just to help out others with this.
The center seat belt actually has 2 buckles. The small one you mention can only be released using a metal pin. There is a small slot where you insert the metal pin. Then you can get that belt completely out of the way when you lay the back seat down. The other buckle is the standard seat belt buckle.
powerlord
Aug 18, 2016 01:50 PM
scottmg
Aug 18, 2016 06:14 AM
Brandon01
Aug 14, 2016 02:31 PM
EZDriver
Aug 2, 2016 01:03 PM
