Rear wheel rumble
Old Jan 3, 2012 | 04:16 AM
twojagsv8's Avatar
It is certainly possible and worth checking but check the other wheels too as it can be hard to tell where the rumble is coming from. Have you had any new tyres put on before this started or have the brakes been worked on?
Regards
John
Old Jan 3, 2012 | 01:21 PM
police666's Avatar
I'd check the wheel balance first
Old Jan 4, 2012 | 08:02 AM
The Chris X's Avatar
Wheel balance could be, brake rotor a possiblity. Jack the car up and see if you have any play in the suspect rear wheel by grabbing the wheel at the 3 and 9 positions and push/pull, then repeat at 12/6 position.
Old Jan 5, 2012 | 12:23 PM
Cosmo's Avatar
Hi Robin,
We had a very similar problem with our '03 V8 S-Type when it was first purchased in 2010. The mechanic found a bad wheel bearing at the passenger side rear wheel. Balance was first checked but it didn't show to be the cause.
Cosmo
Old Jan 25, 2012 | 03:20 PM
R6RYD's Avatar
have you changed the bearing?
Old Jan 26, 2012 | 05:08 AM
Cosmo's Avatar
defer to opening poster
Last edited by Cosmo; Jan 26, 2012 at 05:12 AM. Reason: Sorry, removed reply, posted too quickly!
dsnyder586
Dec 29, 2024 07:39 PM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
innzane
Sep 2, 2015 10:08 AM
