Release for 6HP26 sealing sleeve?
Old Nov 22, 2015 | 03:10 PM
Sean Heberly's Avatar
Default Release for 6HP26 sealing sleeve?
I am trying to remove/replace the sealing sleeve along with pan and filter on a 2004 6HP26 trans and am having no luck. I have read there is a release located somewhere under the pan but I don't know what I'm looking for. Anyone have some information on this?
Old Nov 22, 2015 | 03:20 PM
JagV8's Avatar
I think there are pictures? It's inside, you need the pan off, I gather.
Old Nov 22, 2015 | 03:49 PM
ZenFly's Avatar
If you look down through these Google pics some of them show channels on one end.. https://www.google.com/search?q=6hp2...ih=950#imgrc=_
Old Nov 22, 2015 | 04:19 PM
Six Rotors's Avatar
Here is the info you need.DO NOT TWIST THE SLEEVE!
File Type: pdf
Old Jul 20, 2016 | 12:59 PM
BurgXK8's Avatar
Question Necessary?
Is it really necessary to replace the sleeve when doing a fluid and filter change?
Old Jul 20, 2016 | 01:20 PM
No it's not but you can't replace the sleeve without dropping the pan so if it leaks later...........
Old Jul 21, 2016 | 07:33 AM
Jon89's Avatar
Agreed. If you decide to drop the pan, replace the factory sleeve. The redesigned ones seal better and should have a much lower failure rate....
Old Jul 21, 2016 | 09:57 AM
abonano's Avatar
Also agree. Best preventative maintenance step indeed with the pan off...
Seann1212
Jun 14, 2016 01:13 AM
Anticitizen
Jan 7, 2016 09:56 PM
Sean W
Dec 3, 2015 07:47 AM
Sean W
Nov 22, 2015 10:53 AM
GoodWins62
Nov 17, 2015 12:43 AM
