Removing brake booster vac line?
Old Aug 16, 2009 | 03:45 PM
thaclient's Avatar
Default Removing brake booster vac line?
Hi everyone-
Sorry for such a basic question, but I just wanted to double check with you all before doing something that could screw up the car .
I have been having a bit of a rough idle lately and I can swear I hear a bit of a rushing sound coming from near the brake booster. I wanted to check out the vacuum line for cracks, etc., but this is where I'm having a problem. In every other car I've played around with, it was fairly evident what the vacuum line was, and it was held onto the nipple with a regular [spring-type] hose clamp. On my 2005 S-Type it isn't as clear. What appears to be the vac line is behind and to the right of the fluid reservoir on the brake booster. Instead of a regular hose clamp, there is a 90-degree elbow that seems to rotate into place somewhat like a headlight bulb would- a quarter turn or so would allow it to pop out of place. Is this the right line that I'm looking at? Also, if this is the right line, do I have to rotate it out of place, or is it attached via some other method besides a hose clamp?
Thanks so much for any help in advance.
Old Aug 16, 2009 | 04:08 PM
JagV8's Avatar
Which engine?
Old Aug 16, 2009 | 04:30 PM
thaclient's Avatar
[Facepalms] Sorry about that: 3.0
Old Aug 16, 2009 | 04:41 PM
JagV8's Avatar
The quite common failure is the PCV elbow. It's not that is it? If it might be, searching here should help.
Old Aug 16, 2009 | 08:20 PM
thaclient's Avatar
Sounds like it is close to the brake booster, but I'm going to search and eliminate the PCV elbow first. Thanks.
Old Aug 16, 2009 | 08:44 PM
thaclient's Avatar
Ok, I'm trying to look through the JTIS but can't seem to find the location of the PCV elbow. Where should I be looking? Thanks.
clubairth1
30
Sep 3, 2025 04:38 PM
hafren
23
Jan 3, 2025 11:26 AM
jdzubas
Oct 4, 2015 09:14 AM
JagLove86
Sep 6, 2015 10:36 PM
obwoodie
Sep 3, 2015 07:45 PM
