Reset procedure after replacing CCM, DCCV & Blend Door Actuator? (passenger's side)
Old Oct 22, 2023 | 12:38 AM
pa9johns1's Avatar
Default Reset procedure after replacing CCM, DCCV & Blend Door Actuator? (passenger's side)
2008 Jaguar S-Type 3.0 V6
Any reset procedure after replacing CCM, DCCV & Blend Door Actuator? (passenger's side)
Or is it just plug and play?
Should be receiving my re-soldered CCM back from ModuleMaster on Monday..
Symptoms:
When A/C is on, it blows cool air on the driver's side vents, and hot air on the passenger's side vents.
Old Oct 22, 2023 | 01:34 AM
LLLA's Avatar
I don’t believe there is a reset procedure. However, I would personally pull the battery before installing the new CCM.
Old Oct 22, 2023 | 07:23 PM
pa9johns1's Avatar
Ok i will make sure to disconnect the battery prior to install -- great idea, thanks!
Old Oct 24, 2023 | 03:56 AM
pa9johns1's Avatar
Thumbs up
UPDATE:
Good evening,
WOW -- PROBLEM SOLVED!!
I followed your input and sure enough, after re-connecting the re-soldered CCM and battery it was time to fire it up...
Upon the engine's initial startup I turned on the A/C and began running thru the re-calibration procedure for the vents/blend doors...at first upon activating the system, I felt hot air coming thru the passenger's side again, but as I kept running thru the steps listed BELOW, the air started getting cooler and by the time I came too the final step, it was 100% RESOLVED! Cold air on ALL VENTS!!!
A big thank you to everyone who responded so quickly, that's synergy baby! 🤗🤗🤗
Here's a photo of my S-Type. (these cars are truly timeless, real British styling that endures thru the ages!) 🕑
RESET PROCEDURE FOR A/C SYSTEM AFTER INSTALLING RE-SOLDERED CCM:
Wind the fan up to full, this will take it out of auto
1 Select full cooling -Lo
2 Select full heating - Hi
3 Back to full cooling
• Select face followed by floor
• Then select face again
• Finally select defrost
MSCantrell
Mar 9, 2023 11:35 AM
Gra1963
Jul 22, 2017 05:38 PM
RobinGa
Jun 16, 2016 07:08 PM
Trevor
Apr 23, 2011 09:20 AM
vikingtlm
Apr 9, 2008 07:23 PM
