Reverse lights stay on?
Old Jan 22, 2016 | 10:16 PM
Jason Souhrada's Avatar
Default Reverse lights stay on?
Is this normal? These reverse lights stay on for 10 minutes after I exit my car and lock it up. Not full brightness, just a dim glow.
Old Jan 23, 2016 | 01:41 AM
JagV8's Avatar
No. Someone's done something.
At a guess, fitted LEDs.
Old Jan 23, 2016 | 06:47 AM
Jon89's Avatar
^^ Agreed. The usual downside of fitting aftermarket LEDs is that they tend to stay on for long periods of time after the car is shut down....
Old Jan 23, 2016 | 07:31 AM
Warspite's Avatar
I witnessed the same thing. I installed 10 watt LEDs, believing that would present a sufficient load, but they remained on, although dim. Removing one and replacing with original bulb eliminated that. I picked up an "experimental" bulb carrier from a wreck and will try soldering a resistor in parallel across the reverse light contacts and see if that eliminates that problem. Many LED kits include that resistor.
I also replaced the entire interior lighting with LEDs, and they work perfectly, with no "constant on" condition.
Old Jan 23, 2016 | 02:51 PM
Datsports's Avatar
Ha I'll bet you guys are right I've been there too ! Also bewere of the positive earth frame on the back of the tail light cluster as touching that on the boot/trunk frame is a quick way to fry your RECModule ! It has a fuse but with mine it blew both the fuse and recm.
ajzride
Dec 4, 2016 04:16 PM
R_Rated
Feb 6, 2016 07:48 PM
BlownBrit
Jan 23, 2016 07:14 PM
vnewtonXK07
Jan 23, 2016 02:08 PM
