Reversing sensors
Old Jan 12, 2018 | 10:11 AM
RobbyHughes's Avatar
Default Reversing sensors
Hello all, I have just bought a 2006 s type saloon se 2.7 diesel, my problem is with the reversing sensors, I get nothing from them at all, the previous owner told me they used to work then just stopped, the front sensors work fine, I’ve looked in the boot and the command module is in the tyre well and there are 3 connectors that have wires in each, which one is the front and which one is the rear as thought I could swap the wires around to see if it’s a module fault or the sensors or speaker.
I get nothing from the sensors when I put my ear to them with car in reverse but not started, also any idea where the speaker for sensors is as can’t find on the parcel shelf.
Old Jan 12, 2018 | 10:50 AM
JagV8's Avatar
I don't think you can safely swap any of the wires - definitely a risk of damage not to say confusion.
You can download (free) the diagrams from this site or JagRepair.com - Jaguar Repair Information Resource
Old Jan 12, 2018 | 04:45 PM
Sorry I didn’t mean swap the wires I meant the connectors around, would that make any difference do you think? Any idea of which connector of the 3 does what?
Old Jan 13, 2018 | 03:33 AM
JagV8's Avatar
I really would not do it. Instead do proper diagnosing. You might read its codes!! (Or have them read.)
Old Feb 11, 2018 | 08:32 PM
quick update, I bought a new module which got the reversing sensor making an error beep so that meant the reversing speaker was working and then found that the passenger side corner rear sensor was dead, so I removed that after taking the rear headlight out and replaced it, now everything working as it should thanks for all your help.
jamwilbat
Jul 2, 2015 02:40 AM
MT500
Mar 2, 2015 04:03 PM
alanmurg
Jan 19, 2015 02:53 AM
ATerry
Jan 20, 2010 02:27 PM
Rabt
Dec 20, 2008 10:17 PM
