RPM’s bouncing/ misfires 2004 s 4.2
Old Jun 16, 2025 | 11:31 AM
Todd2's Avatar
Default RPM’s bouncing/ misfires 2004 s 4.2
Anyone seen this? (Video)
At a constant speed under a little load my s type drops rpms and recovers continuously. Thought I had a transmission issue, but the transmission shop saw codes for misfires on every cylinder of the engine.
Took it to a shop who changed out plugs and 2 coil packs, picked up the car and it didn’t fix the issue. Thinking MAF? If I’m going to have shops throw parts at things, I may as well start changing out parts myself and save the labor and markup.
If anyone has seen this or has any advice I appreciate it.
File Type: mov
Old Jun 16, 2025 | 11:46 AM
JagV8's Avatar
I would stop changing parts - it gets expensive and if you happen to use non-OE parts you can make things worse.
Doubt it's the MAF. Leave it be.
Start with OBD. I take it you have (pending) P1000? If so, which OBD monitors have not set?
Use OBD to have a look at all the (not many) sensors you understand, for plausibility.
Check fuel trims - see the many posts.
There's a TC (torque conv) issue that might be the revs thing. Would not affect misfires let alone cause codes for them.
With codes, be sure to quote them (Pxxxx etc).
Dargam
Dec 4, 2024 03:27 AM
MudDog
Oct 4, 2022 04:05 PM
megacattin
Aug 3, 2019 05:58 PM
EsRay
General Tech Help
Nov 20, 2017 04:54 AM
madmark
Dec 30, 2008 01:12 AM
