not running right
Old Dec 3, 2008 | 05:10 PM
madmark's Avatar
Default not running right
I have a 1996 4.0supercharged 6 cin runs ok till you put your foot down a bit than it spulters about you can rev it ok,ish its when its underload it like its missfiring does someone know what this can be[]
Old Dec 3, 2008 | 10:32 PM
dougs02's Avatar
Default RE: not running right
You need to have an analyzer/scanner hooked up to see what codes the computer is setting. Then with the codes, it will point to the possibilities. Post the codes here and someone can tell you what sensors etc. they refer to. Auto parts stores such as Autozone will read the codes for free.
Doug
Old Dec 6, 2008 | 04:41 PM
Doug's Avatar
I agree with Doug...getting codes is a good first step.
If that isn't in the cards then remove the coils and look for any signs of cracking or burning. Coil failures are fairly common on these cars.
Cheers and good luck
Old Dec 6, 2008 | 06:51 PM
Brutal's Avatar
you need to look more at the secondary fuel pump for that problem on a super charged car
Old Dec 6, 2008 | 09:45 PM
Doug's Avatar
ORIGINAL: BRUTAL
I always wondered how you were supposed to confirm that the secondary pump was working..?
Old Dec 10, 2008 | 10:33 PM
Brutal's Avatar
well I use a jumper to activate the pump with the relay removed and then listen for it running in the tank. you can also leave the jumper if the pump does run to see if there is a change it the running. if it then runs fine you need to look at the relay, ecu and wiring, if no change then look at the mass air flow, even unplug it to see if theres a change as the ecu while adapt other sensor info to use when no mafs is hooked up, again if a change its the mafs, if no change keep looking
Old Dec 12, 2008 | 09:41 AM
boycey_xjsport's Avatar
this could be something as simple as condensation in the plug ports this time of year, raly common for the AJ6 engines and somtimes found in the x300's, shot of wd40 or similar in the ports do dispel moisture. start with the basics and move on...
Old Dec 30, 2008 | 01:12 AM
cool's Avatar
read the service recall post
trosty
26
Dec 18, 2022 06:40 PM
cissdm
May 3, 2016 06:02 AM
Doovoe
Sep 8, 2015 05:42 PM
kevo
Sep 8, 2015 09:45 AM
