Rumble strip noise
Old Dec 24, 2013 | 09:03 AM
  #61
johnr's Avatar
it would seam to me that if you are a trained service tech working on anything on the lift. it would be a common practice to mark and replace all fasteners in a drive line in the same position in which they came out.
needing this type of information in a technical publication written for such a person would seam redundant. this type of information would be expected in a do it your self book such as a Haynes or Chilton manual, unfortunately there dose not seam to be any of these for these cars.
Old Dec 25, 2013 | 08:22 AM
  #62
clubairth1's Avatar
Community Influencer
JagV8 you bring up a good point? I can't find where I read that but maybe I am wrong about no converter lockup in 4th gear? I had read that only 5th and 6th lock up but can't find it now?
If anyone has a source for when the ZF 6 speed locks the converter please post it!
Old Dec 25, 2013 | 08:51 AM
  #63
Gus's Avatar
Gus
I have a contact with ZF and I can send him a note but it might take a few days for an answer.
Old Dec 25, 2013 | 09:48 AM
  #64
Gus's Avatar
Gus
Does the 2005 S-Type have a split shaft with a hanger and universal joints? If it does I would be checking them first.
Old Dec 26, 2013 | 08:55 AM
  #65
JagV8's Avatar
google brought me a slightly suspect ZF 6HP26 transmission - Wikipedia, the free encyclopedia
This is a bit less definite http://www.jagrepair.com/images/TSB/...ansmission.pdf
  #66
clubairth1's Avatar
The drive shaft has rubber flex couplings on each end and a split shaft. We do have a drive-shaft support bearing too.
See below:
LnrB
Oct 13, 2015 12:45 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
