S-type 2000 V8
Old Feb 12, 2008 | 07:14 PM
FactoryJaguarTech's Avatar
Default RE: S-type 2000 V8
I know the transmission is just a Ford 5R55N box. It can be rebuilt by any competant shop.
Why did they tell you timing chains?
Old Feb 12, 2008 | 07:17 PM
jag_genius's Avatar
hey im in toronto all those codes are for solenoid faults i wud start with a trani internal solenoid set there like 700 i can help you im in toronto
Old Feb 12, 2008 | 07:21 PM
Genuis. When I look at your avatar I want to throw up. Looks to much like what I had laying in my bay the last two days.....lol
Old Feb 12, 2008 | 07:23 PM
jag_genius's Avatar
2 days?? wiring harness or heads? i am tempting totake a engine and trani like that and make it into a coffee table lol!
Old Feb 12, 2008 | 07:29 PM
jag_genius's Avatar
if it's the shooting snail light .. then it probably just needs the abs module to be reprogrammed
Old Feb 12, 2008 | 07:31 PM
Wiring harness bud. Drove car home tonight. Seems to be ok. No op code for the harness on s/c 4.2, what a lot of work. I have done the n/a harness in vehicle, but no way I was gonna do the s/c one like that.
Coffee table.....I like it. Put two face to face a couple feet apart with a nice piece of glass on it.
Old Feb 12, 2008 | 07:34 PM
jag_genius's Avatar
so i guess you can make up how long it takes... luckly the hole thing falls out smoothly for what failure you replaced the harness for?
Old Feb 12, 2008 | 07:37 PM
P0333 code. Bad splice. THL could only tell me it was 700mm from ECM. I told them I am replacing harness as there is a dozen different harness things go in there 700mm from ECM.
Hooked up meter to monitor voltage drop on ground side of knock sensor. Left it recording min/max and when restricted perf. light came on, ground side spiked to 2.16Volts.
Old Feb 12, 2008 | 07:40 PM
jag_genius's Avatar
well the harness do go to the cheapest bidder to build.. lol more money for us.
Old Feb 12, 2008 | 07:43 PM
Sounds good to me. I wonder how them Indian harnesses are going to hold up?
Old Feb 12, 2008 | 07:47 PM
jag_genius's Avatar
lol i really hope it doesnt get sold ..
Old Feb 13, 2008 | 02:49 PM
jag_genius's Avatar
no these codes set when the solenoid switch fails ..
3jagfamily
Oct 1, 2015 01:49 AM
moff1959
Sep 26, 2015 05:35 PM
