S type 2005 demister grill how do you remove - RESOLVED
Old Nov 9, 2012 | 06:03 AM
jimp6688's Avatar
Default S type 2005 demister grill how do you remove - RESOLVED
Hi all, can anyone help. I have a 2005 stype luxury model jaguar. I have a fine crack in the plastic trim that sits between the dashboard and windscreen .i think it may be called the dash demister trim grill, the crack is in the centre . My problem is i'm not sure how to remove it? It seems tight .
Last edited by GGG; Nov 14, 2012 at 04:31 AM. Reason: Add 'RESOLVED' to thread title
Old Nov 9, 2012 | 07:17 AM
Here's a diagram from the Parts Manual:
The Demister Grille (item 1) appears to have Blanking Plugs (item 3) concealing Plastic Screws (item 4).
After these are removed, it is also held in place with Spring Clips (item 2).
Attached Thumbnails S type 2005 demister grill how do you remove - RESOLVED-s-type-demister.jpg
Old Nov 9, 2012 | 12:26 PM
tbird6's Avatar
Look here;
https://www.jaguarforums.com/forum/s...-rattle-36041/
I did a detailed write up. No screws on defroster panel. Just clips.
Old Nov 9, 2012 | 01:29 PM
Brutal's Avatar
Unless your gonna replace it i wouldnt mess with it. That small single crack will be multiple bigger cracks if you try to remove and glue it. Pull the rubber door seals away from the a post trim. Unsnap the a post trim and using a trim tool (plastic angled piece with a curved handle to slip underneath and pop up) carefully slide underneath the panel and pop up by each clip
Old Nov 9, 2012 | 02:38 PM
tbird6's Avatar
That's a good point. We have not found a lower cost provider than Jaguar either. Some people with multiple breaks have glued it from the back side. I was lucky and just had a rattle.
It does seem to be one of those things that happens as the car ages. Hopefully not every car. I have been lucky so far on my SC hose too. I am at 85K miles and counting on the factory hose
Old Nov 9, 2012 | 03:26 PM
JagV8's Avatar
Romney/Ryan? hmmmm
Old Nov 10, 2012 | 06:32 AM
jimp6688's Avatar
thank you very much Graham , that's very much appreciated. regards jim.
Old Nov 10, 2012 | 06:34 AM
jimp6688's Avatar
Thanks Ryan , very much appreciated !
Old Nov 13, 2012 | 04:32 PM
RizwanSharp's Avatar
Mine was broken too.. Here is what I did..
https://www.jaguarforums.com/forum/s...-repair-70534/
Thanks,
Rizwan
Old Nov 14, 2012 | 04:11 AM
jimp6688's Avatar
Default thanks for the info and pictures , how good was that !
Thanks RizwanSharp that was very appreciated. thanks Jim
Old Nov 14, 2012 | 04:29 AM
Thanks,
Rizwan
Good one, Rizwan.
You can't beat a pic sequence for making a clear explanation.
I think we can safely add 'RESOLVED' to this thread title now.
Old May 2, 2020 | 11:02 PM
Russell11's Avatar
Default Question
Dear Brutal
Can you tell me the part number for a S-Type R demister grille. My car is built November 2002, but complianced March 2003. I am struggling to know which one fits my car. Many thanks.
Russell
Old May 8, 2020 | 11:30 AM
Lotibob's Avatar
Default Demister panel
Same issue with my '05 R...cracked in center. Many body shops now have nitrogen fusion plastic welding equipment to properly fuse the polypropylene or more simply use stainless steel staples melted into the panel. I sell this equipment in my business and will be using the staple system to fix mine, though the crack will still be barely visible. Used the staples to repair split rocker trim and it did nice job of making lasting repair. Most adhesives, short of body shop grade, won't hold up. Or....in the case of my '05 a panel from a Lincoln LS of the same year will fit and it is of heavier construction though slightly different in style.
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
DeaconHull
Aug 28, 2015 05:26 PM
palian
Aug 27, 2015 10:24 PM
divingmom
Aug 25, 2015 07:54 PM
