S-Type 3.0 Stalling Problems
Old Dec 16, 2013 | 01:55 AM
Andyrapps's Avatar
Default S-Type 3.0 Stalling Problems
My 1999 3.0 S-type Has had running Problems For around 6 months.
The symptoms.
Hunting slightly at tick over 800 RPM
after acceleration the revs drop to 1500 for around 20 seconds before dropping to 500 then back to 800.
If performing a manoeuvre i.e 3 ppoint turn the engine will die just as your about to put it in reverse. (about 60% of the time)
very little tick over power,
What I've done so far.
Changed Spark plugs and Ignition Coils (brisk plugs and motorcraft coils)
Changed Air filter (K & N replacement element)
Cleaned Breather pipes
Cleaned Throttle body
Cleaned EGR System
Im not getting any fault messages or engine lights
Can anyone help?
Old Dec 16, 2013 | 03:38 AM
Firstly, welcome to the forum.
My S Type expertise is limited at this moment.
Reading carefully your "done so far", I am questioning the infamous 90deg elbow in the lower section of the "V", under the lower inlet manifold. Many, many threads on here about it and the issues it creates.
I am about to do this to both ours, and I believe fun is about to be had.
Others with significantly more experience will come along sooner or later.
Old Dec 16, 2013 | 09:25 AM
JagV8's Avatar
Probably will be that. You could read OBD LTFT values and would probably find you have a slight air leak all the time then what happens is it cuts out because there's a sudden air leak.
Old Dec 16, 2013 | 11:16 AM
abonano's Avatar
+1 to air leak.
cissdm
May 3, 2016 06:02 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Numwen
Sep 6, 2015 12:30 AM
pocketrocket
Sep 3, 2015 07:44 PM
laserguy
Sep 3, 2015 02:02 PM
