S type 3.0L V6 common faults
Old Aug 5, 2019 | 09:57 PM
Craig Stype's Avatar
Smile S type 3.0L V6 common faults
Hi everyone,
I just picked up a 1999 S type 3.0 V6 auto on the weekend, for fairly cheap from a friends parents.
Its one owner & done 250,000 kms and i would like to make it reliable, and do some preventive maintenance.
I had a quick search for common faults but couldn't really find a thread that shows a list!?
I would greatly appreciate some info and \ or advise on what to replace so i don't get stranded anywhere or while im replacing a few parts i can get in there as well and replace\ inspect common issues.
I will be doing the following shortly:
-Automatic transmission filter replaced and fluid flushed ( shifts a little bit hard time to time, still has factory fluid i believe )
-Looking for possible air leak??? as car really doesn't slow down when not depressing accelerator
-Rocker cover gasket leaking ( drivers side )
-Drive belt and checking pulleys
-Upper coolant hose leaking from plastic nipple going to reservoir
-Oil & filter change, spark plugs, inlet manifold & MAF meter & throttle clean, injectors ultra sonic cleaned
-adjust handbrake cable
I also have noticed if i park in a incline it gets stuck in park if i dont pull the hand brake up before putting in park ???
hissing sound from foot well on rare occasion ( maybe booster ??? )
If anyone has some recommendation on parts to check and or replace would be greatly appreciated
Cheers Craig
Old Aug 6, 2019 | 09:54 AM
kr98664's Avatar
Craig,
Here you go, specifically the parking instructions in post #3:
https://www.jaguarforums.com/forum/s...ncline-183486/
This is a common problem on the early models, and easily avoided if you set the parking brake before shifting into park.
Old Aug 6, 2019 | 10:52 AM
kr98664's Avatar
Is the Check Engine light illuminated? If so, what are the codes? Possibly P0171 and/or P0174?
Here's a good primer on troubleshooting possible air leaks:
JagRepair.com - Jaguar Repair Information Resource
Alex_C
Jun 27, 2017 06:53 AM
PontusL
30
Aug 23, 2016 06:41 PM
dan2222
Jan 12, 2011 01:36 PM
hawaiianjag
Nov 21, 2010 04:37 AM
JagFanatic
Nov 14, 2008 09:52 PM
