S-Type 3.o auto Showing Gearbox Fault.
Old May 9, 2015 | 03:15 AM
Fitchy's Avatar
Default S-Type 3.o auto Showing Gearbox Fault.
I have an S Type 3.0 auto petrol 1999.
I have had no preoblems with my car until the other day.
Driving along i noticed a Gearbox Fault warning on the instrument panel.
I stopped. stopped the engine restarted it and the fault went away. later that day the fault came back.
When the fault is showing the gears dont select properly ie, 1 to 2 ok then they stay there.
When i stop the engine and restart without the fault showing the gears are back to normal.
Help please.
Fitchy (a new member)
Old May 9, 2015 | 03:53 AM
JagV8's Avatar
Check battery voltage after car has not been used for 8+ hours.
If below 12.5V may need replacing.
If at least 12.5V then check there are no OBD codes and read fuel trims.
Old May 9, 2015 | 04:49 AM
I agree with JagV8.
Also, when was the last time the trans fluid was refreshed?????.
Old May 9, 2015 | 08:07 AM
Fitchy's Avatar
Default Thanks.
I have put a new battery on within the last month, it shows green but when I went out to check it, i noticed that one of the terminals was not very tight so I have tigtened it up now, I need to try it again.
I am not an engineer could you please tell me what OBD codes are and read fuel trims?
Im a retired airline pilot and used to leave all the repairs to the mechanics ha ha.
Old May 9, 2015 | 08:09 AM
Fitchy's Avatar
Tomorrow I will go to the garage and have the fluid level in the gearbox checked and replaced if necessary, I supose there is a filter there also?
Old May 9, 2015 | 08:29 AM
JagV8's Avatar
Huge choice - read up using forum Search with
fuel trims
Old May 9, 2015 | 08:32 AM
Fitchy's Avatar
Thanks v8 will do
aholbro1
Dec 29, 2024 06:46 PM
cissdm
May 3, 2016 06:02 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
Jaguar Forums Editor
Jaguar Press release
Sep 4, 2015 09:18 AM
pnwrs2000
Sep 3, 2015 11:55 AM
