s-type 4.0 crankshaft setting peg
Old Jul 16, 2015 | 12:09 PM
kaotikd's Avatar
Default s-type 4.0 crankshaft setting peg
I am working on an out of time 4.0 from 2001 s-type i recently recieved the timing tool kit and I can't seem to get the setting peg to got into the flexplate, it is hitting the ring with the notches. Is there a trick to it or is something wrong. Another "mechanic" changed the engine so not sre what was done with the flexplate. In my understanding the flexplate can only go on one way is this correct.
Old Jul 16, 2015 | 02:58 PM
kaotikd's Avatar
I found the spot the peg fits into. Is the engine going to be at TDC when peg installed? Mine is deffinately not at TDC. The cams are also not in the right orientation with the flat spots up.
Old Jul 16, 2015 | 03:09 PM
I believe the crank is at 45deg? with the pin in, anyway not TDC.
Old Jul 16, 2015 | 06:31 PM
kaotikd's Avatar
That makes me feel better, now i can retime it and hopefully nothing is damaged.
Old Jul 16, 2015 | 07:06 PM
motorcarman's Avatar
The AJ28 crank lock tool is DIFFERENT from the AJ26/27 tool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bob gauff
mrplow58
Jan 21, 2024 05:53 AM
RoyLittle0
May 25, 2023 02:38 AM
Quantico
Oct 13, 2015 10:34 PM
34by151
Sep 6, 2015 05:14 PM
