S-type Aux input
Old Mar 7, 2016 | 06:03 PM
Singto's Avatar
Default S-type Aux input
hello everyone,
Does anyone know how to connect smartphone to my car audio to listen the music from my smartphone??. i don't wanna change my radio factory. if it can not, i have heard that i can buy aux input and connect with my factory radio..
I have Jag s-type 2003
thank you
Old Mar 7, 2016 | 06:19 PM
JagV8's Avatar
Short version: car designed in 2000. Tech has changed in those 15 years. You can't do it easily and cheaply.
Decide your budget.
Old Mar 7, 2016 | 06:25 PM
Singto's Avatar
Thank you very much JagV8. anyway no another way to do it?? i have seen many cars (older that s-type) install the aux input by using the aux adapter. i have been wondering that if its would be possibly to install in s-type.
Old Mar 7, 2016 | 06:29 PM
JagV8's Avatar
Buy ACM.
Not cheap.
Datsports's Avatar
go to this link
https://www.jaguarforums.com/forum/s...e-test-135194/
go to post no#3 and click that link if your interested
very easy install . cool integrated features . works great !
or there is fm modulated and parrot I've had both and don't sound as good as this !
Old Mar 7, 2016 | 06:35 PM
Datsports's Avatar
Originally Posted by JagV8
Buy ACM.
Not cheap.
acm is great but is twice the price of veffbox,and no BT
and quite hard to find second hand at a reasonable price ,
also controls and format for searching music is not easy as well.
also three times the effort to install.
take this into account .
Old Mar 7, 2016 | 06:40 PM
JagV8's Avatar
See post #2
Old Mar 7, 2016 | 08:02 PM
Gus's Avatar
Gus
See if this link helps. I got 2 units from them one for my XK8 & S-Type. If you do not see it call them.
Link Discount Car Stereo
Old Mar 7, 2016 | 09:05 PM
Singto's Avatar
i found.. iSimple iS7705 Charge and Play your new iPod or iPhone on any car radio. it would be work ?
Old Mar 8, 2016 | 05:03 AM
Datsports's Avatar
Yes it will work but won't sound very good , it's FM modulated ! Normally quite a bit less voume and clarity than normal radio stations and cd quality !
If that's your budget then it will do I guess!
Old Mar 8, 2016 | 12:28 PM
kr98664's Avatar
Hello and welcome,
I have a different verson from iSimple: ISFM22. I did not see the IS7705 when I purchased mine. From what I know now, I probably would have purchased the one you're looking at.
The IS7705 uses a direct cable connection between the iPhone and the FM modulator. Mine uses a Bluetooth connection. Mine works okay, but Bluetooth was never designed for high quality audio transmission, so some music has that echo-like, recorded in a bathroom sound. I don't believe you'll have that problem with a direct data cable connection.
I keep my iPhone on a dash-mounted dock with a built-in charging cable, powered by a separate hidden USB charger. I like your version, with the data cable also acting as a charger. If you want to keep your phone in a dock, you'd probably have to modify it somewhat to work with the iSimple cable.
I looked at the Amazon reviews. It appears the cable end of the IS7705 has had lots of reliability issues. It would probably be fine if the cable is permanently fitted to a dock, but if you'll be plugging and unplugging the cable by hand, I doubt it will hold up. I highly recommend a dock, because to change songs, etc., you must access your iPhone. You don't want to be messing around with your phone loose on the console or dash.
Another issue is the on/off switch supplied with the kit. It is very big, almost 3/4" in diameter. I replaced it with a tiny toggle switch from Radio Shack.
If you'd rather go a different route without any wiring or need for a switch, there are plenty of FM transmitters out there. Most are inexpensive units that plug into your cigarette lighter, with no wiring connections. Just set your radio to the FM output of the transmitter, and you're all set. Some versions use a Bluetooth connections between your iPhone and the transmitter. Others use a cable. Both types are adequate. I used to have a special FM transmitter dock for my iPhone 4 (with the big connector) and it worked great. I recently upgraded my phone, and couldn't find anything kind of transmitter dock with the new, smaller connector. I'd have gone that route for simplicity if available.
Old Mar 8, 2016 | 05:19 PM
Singto's Avatar
thank you very much. i just wanted to connected my iPhone to my jag radio to listen the music. just i want to find whatever to connect to my iPhone
Old Aug 30, 2023 | 06:46 AM
DiltWasney's Avatar
This is an old thread but if someone searches for this, there are ways to add aux to S-type, for instance:
Aux input adapter
JagAux adapter
Old Nov 30, 2023 | 06:50 AM
kiloslanga's Avatar
Aux input adapter
JagAux adapter
Thx just used the link and saved $30 compared to eBay’s price. Let’s hope it arrives. I’ve never shopped from a uk website before.
Old Dec 9, 2023 | 01:20 AM
kiloslanga's Avatar
https://www.incarconnections.co.uk/j...x001-ipod.html
Arrived today! Installed in 15 minutes and man it not only saved me a bunch of money but it sounds amazing. Thx
DaveE
23
Sep 16, 2017 04:44 PM
DVPV
Feb 6, 2013 04:51 PM
skelnik
Mar 17, 2010 01:45 PM
jaakennuste
Audio/Visual Electronics
Dec 1, 2008 11:44 AM
M4rc3l
Jul 7, 2008 07:07 PM
