s type cooling system gurgle
Pop the hood, VERY CAREFULLY loosen the purge screw on top the coolant reservoir (do not force it), motor up to temperature, heat on high and watch for bubbles/coolant, tighten purge screw.
If you are inquiring because you hear gurgling behind glove box when vehicle is shut down, there is a TSB, expensive if not under warranty. BTW most owners will just live with the gurgle.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
