S Type fuel door latch
Old Jul 26, 2012 | 06:39 PM
  #61
Six Rotors's Avatar
My fuel filler lid worked fine from the dash switch,but the emergency release cable in the trunk was inoperative.I have just completed removing the assembly and fixing the emergency release cable,which just needed freeing up and lubricating where it went into the actuator.So now it is back in place and both actuation modes are functional.
The point here is that my car is a 2004 and has a different design of latch and actuator.For anyone with a 2005 and up may want to look at fitting a 2000-2004 type latch motor assembly.I am not sure if would be necessary to change the door as well since I am not familiar with the 2005 door.
Old Dec 27, 2012 | 07:39 AM
  #62
1320racer's Avatar
Default Add me to the list (broken fuel door pin)
My fuel door was stuck on my last fill. Had to break the plastic pin to open it. I wish I would have seen this thread and lubed the pin before this happened. Not sure if I'm going to replace the parts or remove the spring. I will look closely at it soon and render a decision on modifying or just replacing the parts. This appears to be the first pin failure on my 2005 STR with almost 75K miles.
Old Dec 27, 2012 | 08:00 AM
  #63
Jon89's Avatar
Keep us posted on what approach you decide to take....
My 2005 S-Type is on its third plastic pin (both latch failures occuring while the car was still under the factory warranty). I've kept this third plastic pin generously lubed with white lithium grease since it was installed in 2009, and that seems to have done the trick....
Old Dec 27, 2012 | 09:10 AM
  #64
clubairth1's Avatar
Community Influencer
I have lubricated the fuel door pin as recommended on this thread. My 2005 fuel door works perfect and is still the original factory piece at 86K miles?
Old Dec 27, 2012 | 12:08 PM
  #65
Robinb's Avatar
Thank you guys for refreshing this thread, because I was not previously aware of this problem. I have obviously been living on borrowed time here, all the while being ultra-fussy about keeping the fuel hatch compartment clean and dry on my '05 STR with 61K miles. Now the entire latching mechanism has been carefully lubed with lithium grease.
Old Feb 13, 2013 | 05:46 PM
  #66
jvane's Avatar
does anyone know how to remove the actuator/solenoid to fit a replacement?
john newcastle uk
Old Feb 14, 2013 | 08:09 AM
  #67
JagV8's Avatar
It's been posted either here or on the UK forum. Try Search on both with a few likely keywords. Each allows restriction to only the right forum if you use Advanced Search.
It's probably also in JTIS, free download...
Old Mar 20, 2013 | 02:32 PM
  #68
larrymelton's Avatar
I have the opposite problem the fuel door wont open I can hear the relay when the door release button is pushed. Are they using a solenoid to release the door or is it a small motor?
Old Aug 4, 2013 | 09:38 AM
  #69
skind's Avatar
Default S Type fuel door actuator
I recently had an unpleasant experience when trying to buy a fuel door actuator for my 2005 S-Type. The online parts stores could not come up with the electric actuator and would only reference some of he plastic pins and release pieces. They refused to look under the electrical section of their parts catalog and would only refer me to pieces in the body panel section. Out of frustration I bought a fuel door actuator for a Volkswagen Jetta. This is a Siemens/VDO manufactured part and is identical to the one that was in my Jag. I don't recommend this practice but was left with no other choice.
Attached Thumbnails S Type fuel door latch-0719131842.jpg   S Type fuel door latch-0719131843.jpg   S Type fuel door latch-0719131843b.jpg
Old Aug 4, 2013 | 12:25 PM
  #70
Robinb's Avatar
Originally Posted by skind
I recently had an unpleasant experience when trying to buy a fuel door actuator for my 2005 S-Type.... Out of frustration I bought a fuel door actuator for a Volkswagen Jetta. This is a Siemens/VDO manufactured part and is identical to the one that was in my Jag. I don't recommend this practice but was left with no other choice.
How exactly did you figure out that the Jetta part was an exact match?
Would be interesting to see examples of parts from other non-Jag sources that can be used on the Jag S-type. For instance:
Fuel door activator.......... Volkswagen Jetta
Battery.......................... Interstate, Optima
Wiper blades.................. Napa
Fuel pump..................... Europarts
Radiator........................ ?????
S/C coolant recirc pump.. Europarts
Old Aug 4, 2013 | 12:30 PM
  #71
JagV8's Avatar
Are the parts not in JEPC? It's a free download.
Old Aug 4, 2013 | 03:00 PM
  #72
Robinb's Avatar
Thank you, but my guess is that JPEC does not list VW Jetta as an alternate source for S-type fuel door actuators.
Old Oct 12, 2013 | 07:54 AM
  #73
ToffeeApple's Avatar
Thumbs up Simple Job, Thanks
Hi Guys and Gals,
Just thought I would say thank you for this thread. I have a 55 plate UK S-Type 2.7 V6 diesel and the pin that retains the fuel door in sheared, as per this thread after 9 years of owning the car!
Just bought a XR857532 pin and actuator for £15.64 + VAT (£18.77) from H.A. Fox's Parts Department in Guildford, Surrey, UK. Gave them a call and they had one in stock! Very helpful guy there, who "knew his onions" as such - even checked the VIN to match the part to ensure it was the right one!
Removed boot floor liner, and RHS boot lining pulled back, removed four 10mm bolts holding the black plate in, disconnected wiring connector from existing actuator and undid one screw nearest the opening on actuator (not removing but loosening - keyhole mounted), and the old broken part popped out nicely. Put new part in and reversed removal instructions to complete. Took 22 minutes (couldn't find a 10mm spanner and 60mm ratchet extender in the garage)!
Was debating a homebrew self engineered replacement, but at £18 for new pin and new actuator, and 20 minutes of my time, seemed like a far better option! The weather was even on my side!
Just to mention the replacement part was identical except for the actuator to metal arm coupling, which now ensured that the pin is at 90 degrees to the motion, rather than allow it to be slightly offset...
Many thanks.
James.
Old Oct 12, 2013 | 09:31 AM
  #74
clubairth1's Avatar
Good feedback James!
That's the kind of useful information that really helps!
I am just glad I read this thread and sprayed some grease on the pin. No problems on my 2005 at 94K miles.
Old Oct 13, 2013 | 01:52 PM
  #75
BKSinAZ's Avatar
My pin just broke off the actuator... I was able to remove the entire actuator, but the broken part seems to only be the black pin that "was" attached to the end. It is missing now. How... or what part do I buy for replacement? 2005 Jag s-type USA
Old Oct 13, 2013 | 02:20 PM
  #76
BKSinAZ's Avatar
Originally Posted by EZrider800
Mine broke about 3 years ago so I went into my garage and found a piece of pretty thin sheet metal. Something that could be bent in a vice with a hammer or pliers without being heated or anything. I fabricated a replacement in about 15 minutes. It's worked like a charm for over 3 years. No more plastic crap to break!!
how did you attach the fabricated pin to the spring where the original black plastic pin sat? Any pictures or specifications of the fabricated part?
Old Oct 25, 2013 | 01:16 AM
  #77
mauiman1959's Avatar
Hi Jag-genius,
The clip on the inside of my fuel door has broken and I was wondering if you knew where I could get a new one. The last six numbers of my vin isL72621.
Thank you.
Old Oct 25, 2013 | 01:45 PM
  #78
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Originally Posted by Jon89
Jaguar Corporate, are you listening to us ????
Ans: No.
Old Oct 25, 2013 | 02:06 PM
  #79
JagV8's Avatar
If they are listening, they're not making any more S-Types so would only affect F-Type etc.
Old Oct 25, 2013 | 02:22 PM
  #80
phaelax's Avatar
My gas door doesn't stay closed. The little plastic latch moves freely back and forth. If you pull the release cable in the trunk, you see it doesn't do anything. Is this the plastic pin everyone is talking about? I'm tired of driving with my gas door partially open.
