s type gear box problem
Old Mar 8, 2012 | 05:05 AM
westwood69's Avatar
Unhappy s type gear box problem
Hi guys.... i currently own a s type 53 plate automatic jag and im having a problem with the gear box...... i went out to my car yesterday morning started as normal put the car into reverse to get off the driveway then put the car into drive an because i live on a hill the car just started to roll but didnt have any power when i accellerated after after a few seconds the car cut out an wouldnt start again .... the gear box thinks its in reverse and the reverse lights are on but the gear lever is stuck solid in park .... could any one explain whats happened an how i can fix it any help would be most appreciated .... thanks for reading
Old Mar 8, 2012 | 05:28 AM
JagV8's Avatar
Car details? Engine? etc
Also, you'll need to follow the new member stuff you've not so far done (post an intro in the right place etc) but welcome in advance LOL
Have a Search for each of:
transmission bolt
shifter
linkage
stuck in park
Old Mar 8, 2012 | 05:42 AM
westwood69's Avatar
oh sorry.... ill do that asap.... the engine is a 2.5l V6
Old Mar 8, 2012 | 05:47 AM
Have a look on the driveway for the bolts if they have dropped out.
Old Mar 8, 2012 | 06:19 AM
westwood69's Avatar
just been reading a few posts on this problem apparently it should be to do with 2 bolts on the transmition selector cable abrutment bracket fitting coming loose or falling out so im gunna go check those ..... thanks
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
GuernseyJag
Nov 8, 2017 10:40 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
gene1
Aug 27, 2015 08:56 PM
