S-type heating problem
Old Nov 26, 2013 | 05:50 AM
william1's Avatar
Default S-type heating problem
Hello
Can anyone advise re this problem. Replacement fan fitted but after that heating or air con always blows hot air even on LO. Only way to manage is push climate on and when it gets too hot, switch off. Unable to get any cold air!
Any ideas welcomed.
Old Nov 26, 2013 | 07:07 AM
police666's Avatar
try search, hundreds of threads with soloution
Old Nov 26, 2013 | 12:56 PM
tbird6's Avatar
Please help us?
What year and engine?
Old Nov 26, 2013 | 03:19 PM
Mbjezior's Avatar
I'm going through the same issue...blows full hot...when selected to lower temp the left blow full hot yet the right vents are cooler than left sides...but nowhere 61. I replaced my DCCV over the weekend- did NOT fix issue...next is to pull the CCM to see if there is a burn...will also check freon and pressures...will keep posted...
I've read that the DCCV is usually the culprit....but if that went bad more than likely the CCM followed shortly after! (Constant voltage causes it to burn out)
Old Nov 27, 2013 | 05:09 AM
william1's Avatar
Default Air con/heating problem
Originally Posted by tbird6
Please help us?
Hi, thanks.
Year is 2004 (december), 4.2 V8
Best wishes
William
Old Nov 27, 2013 | 08:18 AM
police666's Avatar
DIY: Diagnose It Yourself - JaguarClimateControl.com
Old Nov 28, 2013 | 05:15 AM
william1's Avatar
Default re heating problems
Excellent link says it all. Thanks again.
Old Nov 28, 2013 | 08:54 AM
clubairth1's Avatar
Community Influencer
To help other people post back when you fix it. It does sound like the common lack of heat problem but maybe not?
Numwen
Sep 6, 2015 12:30 AM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
Bcrary3
Sep 3, 2015 03:48 PM
laserguy
Sep 3, 2015 02:02 PM
