S-Type Jaguar Control Arms & Ball Joints
Old Aug 15, 2011 | 10:48 AM
gabrielduenas's Avatar
Originally Posted by cstich
If buying on ebay, I'd buy them from Euromarque - they are in Houston and are a large rebuilder and manufacturer (e.g. inner tie rod ends - otherwise not available for ZF steering racks) of Jaguar parts.
As a customer, I can also vouch for Euromarque, Ed is a stand up guy. I had a problem with parts from another vendor on Ebay, Euromarque infomed me of the correct parts and even gave me a great deal on rear tie rods and links!!
Old Aug 16, 2011 | 10:05 PM
Christian 96 XJR's Avatar
Motorcars LTD (also in Houston) is also great.
Old Aug 16, 2011 | 10:28 PM
mikewv100's Avatar
I agree Ed at Euromarque has quite a selection and is very informative. He worked for Jag Service quite a while and at times has even discounted his already low parts for sale of more than 1 part at a time
The upper arms on cars up to mid 2003 m4??? are about 1/3 the cost of later serial numbers. There is no aftermarket manufacturer of upper front arms later than early 03.
Bummer.
Old Aug 17, 2011 | 09:59 AM
Just wanted to share this, if anyone needs upper arm bushings and the ball joint is not too jacked up:
JAGUAR FRONT UPPER WISHBONE CONTROL ARM BUSH BUSHING | eBay
i recently bought an universal dust boot that fits the upper BJ at Napa Auto Parts, its a 5/8 shaft opening.
Old Aug 18, 2011 | 08:31 AM
mikewv100's Avatar
Default Bushings
Not bad price. Good option, but I have replaced all 4 upper control arms and the ball joint was bad on all 4. I was hoping when I started that noise was from bushings, but all were the ball joints
Maybe you would get lucky
Old Aug 3, 2013 | 11:30 AM
kblood's Avatar
Default Replacing right rear lower control arm
HI,
I own a S type base 2003, and need to replace right rear lower control arm and would like to ask you what could be the part number for both the whole component of lower control arm and bushing itself.
What I found after few hours of searching on internet is that the control arm really cost an arm and leg and I would like to save some money by just replacing bushings.
Link for lower control arm on ebay : Jaguar s Type Rear Lower Control Arm RH C2P10436 New | eBay
Please share your any idea of the part and replacement.
Thank you in advance for your help!
Old Aug 4, 2013 | 08:12 AM
JagV8's Avatar
See (or Search for) the Definitive wishbone thread
on the UK forum
Old Aug 5, 2013 | 07:32 AM
  #28
mikewv100's Avatar
Default Lower control arm bushings
Call me. I can show you how to save a lot of money and fix the problem.
Mike 304-720-4441 3.04-444-2081
Old Aug 17, 2013 | 04:03 AM
grandhaze's Avatar
Heres my new ball joint. Right type installed today. $50.ebay Paul
Attached Thumbnails  S-Type Jaguar Control Arms & Ball Joints-20130817_105715.jpeg
Old Aug 18, 2013 | 07:27 AM
  #30
mikewv100's Avatar
ebay item number 330931858676 Bushings for lower control arm rear all years except R Type. This is for both sides. Also has listings for one side only.
Old Oct 17, 2013 | 06:24 PM
  #31
Lt0302's Avatar
Question Looking for front upper ball joint
Anybody out there that knows of a supplier or has any leads would be much appreciated!
Old Jul 22, 2019 | 11:59 AM
  #32
Martez40's Avatar
Default Bolts Sizes
Do any one know the bolts size for a 2002 Jaguar s-type rear lower control Arm
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
ControlIssues
Sep 3, 2015 07:38 PM
RaceDiagnostics
Sep 1, 2015 05:47 AM
dpappyp
Aug 27, 2015 06:31 AM
