S-Type Misfire
Old Nov 2, 2017 | 02:43 PM
jaguar258's Avatar
Default S-Type Misfire
2001 S-Type 4.0L Sport
I have a problem where my Jag misfires at around 40mph and it idles rough. I have changed plugs and coil packs but the misfire still happens. What can I try next??
Old Nov 2, 2017 | 07:36 PM
Welcome to the forum jaguar258,
I've moved your question from UK & Eire Region to S-Type forum. This is the place to post technical questions about your model.
Old Nov 3, 2017 | 06:29 AM
JagV8's Avatar
Might be timing - have you changed the tensioners etc? Your engine is on borrowed time if not
Or maybe an air leak - use OBD live data to look at fuel trims.
Old Nov 3, 2017 | 10:32 PM
NBCat's Avatar
Did you find oil in the spark plug wells when your replaced the spark plugs and coil units? If so, the cam cover gasket(s) and spark plug seal(s) are leaking and must be replaced.
Is the MIL on and are there any DTCs stored? If so, post them here.
Old Feb 22, 2022 | 11:44 AM
Perry L moore's Avatar
Default 2005 Jag Misfire
my Jag Misfire about every other week,had plugs and coils change
enigma
Jan 2, 2017 11:40 AM
Undertaker
Nov 23, 2016 04:26 PM
mrkaine
17
Nov 22, 2016 01:06 AM
Zech Pinto
Nov 18, 2016 05:50 PM
Brianna Renee
Oct 25, 2016 09:59 AM
