S Type parking aid.
Old Oct 17, 2012 | 02:57 PM
wilco's Avatar
Unhappy S Type parking aid.
2005 S Type rear parking aid does not work. I get the 3sec beep, have changed the module{new one} ,got someone to listen to all sensors and all making clicking noise. Have had it pluged into computor and showing no faults. Any ideas.
Old Oct 17, 2012 | 08:52 PM
oldmaned's Avatar
Default oldmaned
Check the parking aid speaker located under rear package shelf.
Old Oct 17, 2012 | 09:19 PM
motorcarman's Avatar
The Reverse Parking Aid module should have faults logged but you WON'T read it with a standard OBDII scanner. That reads the ECM but NOT the Body or Chassis codes.
bob gauff
Old Oct 18, 2012 | 06:13 AM
wilco's Avatar
Thanks for reply but i get a 3sec beep is that not coming from the same speaker?
Old Oct 18, 2012 | 07:26 AM
JagV8's Avatar
It's irrelevant which speaker. The system has detected a fault and if the sensors are OK then it's somewhere else. It's not the speaker. To read faults see Bob's post.
Old Oct 18, 2012 | 09:18 AM
oldmaned's Avatar
Default oldmaned
I am not sure about the three second beep,but if your sensors are clicking and can't be heard through the speaker,I would think the speaker is bad. There is a lot of info on this site. Try searching for rear park assist. My 2001 S Type had similar problems and the speaker was the problem with it.
Old Oct 19, 2012 | 04:30 AM
JagV8's Avatar
oldmaned - yours did the 3-second beep? It sounds very unlikely.
Old Oct 19, 2012 | 05:33 AM
wilco's Avatar
thanks..Is the speaker located in the same place on all S type jags. {think iv read under the parce shelf.}
alan.
Old Oct 19, 2012 | 08:37 PM
oldmaned's Avatar
Default oldmaned
I think it beeped a few times before the speaker stopped working.
I believe all S Types have the speaker under the parcel shelf. You can probably determine this by searching this forum. I took mine to american tire company and they replaced the speaker without removing the parcel shelf. I believe they charged me $80.00 for labor. I bought the speaker from the Jag dealer for about $60.00. Their estimate for labor to replace it was over $200.00.
Old Oct 20, 2012 | 06:43 AM
barney100golf's Avatar
alan.
Get the codes read on a Jaguar enhanced code reader like enginuity etc. that will pinpoint the sensor which has failed, it is pointless charging about with out basic info
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
tberg
Sep 7, 2015 07:32 AM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
