S Type R ballast replacement ?
Old Feb 4, 2010 | 02:25 PM
Riski's Avatar
Default S Type R ballast replacement ?
I finally got the new ballast in for the drivers side xenon. To remove and install it, does the headlight have to come off which means the whole front end basically....or is there a way to sneek behind there to get the job done?
Any tips would be great!
Old Feb 4, 2010 | 03:00 PM
Brutal's Avatar
Take the bumper off, it only pays 1 hour theres no way to get behind there and take out the torx bolts
Old Feb 4, 2010 | 03:24 PM
Riski's Avatar
That is what I thought......Silly design!
Old Feb 4, 2010 | 03:42 PM
Brutal's Avatar
WELL THEYRE DESIGNED TO BE "LIFETIME" PARTS LIKE TRANS, DIFF FLUID AND OTHERTHINGS..........(LIFETIME OF THE WARRANTY PERIOD)
Old Feb 4, 2010 | 04:01 PM
Riski's Avatar
HAHA.....Was not worth using the extended warrenty at first......next time I WILL!
Old Feb 4, 2010 | 04:39 PM
Brutal's Avatar
Should have let me know i have good extra used and new ballast. It really only takes about 20-30 mintues to do and you only have to loose the whole top cover and grill then the wheel arch and inner fender 10mm on the affected side. You can pull the bump cover away and around to work with since its urethane
Old Feb 4, 2010 | 04:56 PM
Riski's Avatar
I kind of did ask around and made a post about it
https://www.jaguarforums.com/forum/s...ad.php?t=32195
......no one said they had extra parts.....Even posted in teh for sale section to the one person who can get parts cheap from the dealership and no reply.....
All well, it is here now....Ill do it sunday morning as well as a oil change and misc stuff.....
Will hit you up if I need anythign else though first!
Old Feb 4, 2010 | 10:25 PM
Brutal's Avatar
well I dont read everything, I dont have alot, but I do have Hid stype headlight parts and assemblies
Old Aug 16, 2010 | 07:31 PM
rangerhulk's Avatar
Brutal i need a ballast, would be interested if you still have it. E mail me rangerhulk@yahoo.com
Old Aug 16, 2010 | 08:28 PM
Enthusiast's Avatar
me too. mjcreel@hotmail.com Riski, do a writeup with pics please?
Old Aug 16, 2010 | 08:49 PM
Enthusiast's Avatar
Let's talk about a package deal. I send you my lights, you send it back fixed (adjuster is broken) with the ballast.
Old Aug 16, 2010 | 09:01 PM
Jagtec1's Avatar
FWIW, I have replaced the ballast without removing the bumper/lamp assembly. It can be done.
Old Aug 16, 2010 | 09:24 PM
Brutal's Avatar
emails sent
Old Aug 17, 2010 | 04:24 AM
Enthusiast's Avatar
How?
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
martybmw
Aug 31, 2015 08:41 AM
Aegis21
Aug 27, 2015 08:30 AM
dpappyp
Aug 27, 2015 06:31 AM
