S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )
Old Feb 24, 2015 | 03:23 AM
User 070620's Avatar
Default S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )
Hi forum,
this is the first time that i write on S-Type R page.
i want know if i can change my XKR intercoolers with S-Type R intercoolers.
this is because i think that i can do dynamic air induction like S-type R by Ferlito but this is possible only with S-Type R configuration.
What part i must change?
do you think that it is possible?
Many thanks
Attached Thumbnails S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )-racing-jaguar-r-engine-compartment.jpg   S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )-racing-jaguar-r-engine-supercharged.jpg
Old Feb 24, 2015 | 07:06 AM
XJR-99's Avatar
How about this XKR style?
https://www.jaguarforums.com/forum/m...ing-car-95277/
Old Feb 24, 2015 | 07:24 AM
Originally Posted by XJR-99
i know it! rrrracing ! in one photo, you can see another pulley aver the supercharger pulley in drive shaft .
who knows what action the small pulley...
Old Feb 24, 2015 | 07:53 AM
ccfulton's Avatar
It should fit on the engine just fine, but I doubt you would be able to close the bonnet. There is not much clearance as it is.
Maybe if you did one with a ram air hood scoop?
Old Feb 24, 2015 | 08:02 AM
our idea is to do a direct air intake but also a new bonnet like Arden
Attached Thumbnails S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )-image_2143.jpg   S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )-ordering-choose-351.jpg
Old Feb 24, 2015 | 08:03 AM
XJR-99's Avatar
I may ask this from a person who should know.
edit: I get answer from him by tomorrow
Old Feb 24, 2015 | 09:24 AM
XJR-99's Avatar
In which photo did you see the extra pulley?
Old Feb 24, 2015 | 09:41 AM
Tijoe's Avatar
Yes, all the STR parts will fit on your engine. You will need the intercoolers, the rear inlet manifold, don't know if the XJR throttle body will fit, or if you need to use the STR throttle body. You will need the STR EGR body and tube, if your car has a different EGR tube on the exhaust manifold you will have to adapt it some how. You will need the STR superchargers outlet manifold and flex joints so that you will match up with the bypass valve and its flex coupler. Hopefully you will get the vacuum valve that operates the bypass valve with the inlet manifold. Once you have all these parts, you can put on your new style inlet manifold.
Probably cost you $600 to $1K for all the parts off E-bay.
There are still people wondering which inlet sytem and intercoolers are better. STR style or XKR. Air flows and distributes into the STR intercoolers more evenly, and they both have the same size cores, but the STR's 180 degree inlet through the throttle body appears to be more restrictive.
On a stock motor, other than your proposed inlet style looking good, doub't if you will gain more than a few HP changing the inlet and all the associated parts. A lot of money for looks and small gains. Go for it! sound like a fun small project. Or,
Save your money and put on an AVOS KB twin screw...
Old Feb 24, 2015 | 09:48 AM
Tijoe's Avatar
One other comment. If you look at the race car images you posted, I would wager that they wanted the space where the stock air intake sits for their oil recovery container. Not much room in the STR's engine compartment to place a large container. They probably figured that a straight in air intake gained them a little more outside cool air and some needed space. Several years ago, I did a lot of research on trying to contact the race team and the company that prepped those cars. I wrote them several E-mails and they never responded.
Old Feb 24, 2015 | 09:49 AM
XJR-99's Avatar
No need to ebay. Just buy all of those from my garage - and maybe some more interesting performance parts
Old Feb 25, 2015 | 03:51 AM
this is the photo
Attached Thumbnails S-Type R intercoolers VS XKR intercoolers ( for 4.2 engine )-10.jpg
Old Feb 25, 2015 | 03:58 AM
read here:
https://www.jaguarforums.com/forum/s...2/#post1169298
i know Ferlito. When you write, tell him that i give you his email ( Luca from Grosseto, Tuscany ).
had you use this email? autosport.ferlito@libero.it
Old Feb 27, 2015 | 09:20 AM
XJR-99's Avatar
this is the photo
I guess that's for dry sump, but let me ask from him.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
KarimPA
Sep 3, 2015 07:32 PM
pnwrs2000
Sep 3, 2015 11:55 AM
TC Johnson
Sep 2, 2015 09:30 AM
