S-Type STR Low Level Radio Static
Old Jan 24, 2023 | 05:59 PM
DigitalDisaster's Avatar
Default S-Type STR Low Level Radio Static
The radio in my wife's '07 STR has always been someone static at lower levels but sounds good at higher levels. I've checked connections at trunk as best as possible with no answers. Anyone experienced this? I'd replace the radio but because of integration, this isn't feasible for me.
Old Jan 25, 2023 | 04:29 PM
Sportston's Avatar
Run a good fresh earth to the stereo and install a suppressor on both permanent and ignition lives.
Old Jan 25, 2023 | 05:59 PM
Thank you for that. I'm assuming good ground to the head unit and not trunk amp?
Old Jan 26, 2023 | 02:03 AM
JagV8's Avatar
It's odd that it's worse at low volume levels.
Old Jan 26, 2023 | 09:56 AM
kr98664's Avatar
Could you be getting feedback from the alternator? That's usually more of a whine, not static, but who knows. Easy enough to rule out. Compare the audio with the engine on and off, and listen for any difference.
Old Jan 26, 2023 | 10:42 AM
No, it's not spark-related noise. More accurately, it sounds like a fried tweeter or bad signal - very scritchy, were that actually a word
Old Jan 26, 2023 | 11:18 AM
kr98664's Avatar
Maybe the audio system is fine, but the problem is that new-fangled noise you whipper snappers call music these days...
Old Jan 26, 2023 | 04:27 PM
Sportston's Avatar
Are you sure it isn’t a faulty speaker? Have you tried unplugging each speaker in turn to see if it is a faulty speaker?
And yes a good earth and suppression to amp AND head unit is a good idea.
F-type-r-2022
Oct 18, 2022 03:50 AM
Zeidan
Apr 1, 2012 09:56 AM
nixx
Dec 13, 2010 12:23 PM
Jan 15, 2006 02:36 PM
