S Type V8 2001 Heater problems
Old Oct 7, 2011 | 01:57 PM
kurt beaton's Avatar
Default S Type V8 2001 Heater problems
Hi i'm after a bit of advise,
2001 S Type V8 only got 2 weeks ago and when i went to use the heater today i noticed it never worked,
With the heater on full it blows cold on drivers feet and window vent. and only slightly warm on passenger window vent and nothing out on the feet,
Any ideas please??
Old Oct 7, 2011 | 02:22 PM
bfsgross's Avatar
Be sure to purge all air out of heater core circuit. Then go from there.
Old Oct 7, 2011 | 02:25 PM
JagV8's Avatar
Quite a few things it could be, including a DCCV (heater valve) stuck closed (commonly fail open, but hey), an air lock (fairly common), blocked heater core (rare), failed module (commonish, usually due to the valve taking it out).
If you measure voltage on both sides of the 3-pin DCCV connector to the middle, they should vary as you change the selected temperature I think. If they do, the module's OK. (If they don't, not sure you can condemn the module as it could be getting bad data?)
Heater problems are common so well worth reading previous threads for ideas.
Old Oct 8, 2011 | 11:08 AM
Lots of people are telling me thats its the "DCCV" sounds like a lovely job!! where abouts is it situated and how hard a job is it??
My friend is top gears mechanic would he be able to do the job or does it have to go Jaguar.
Thanks for ya help guys.........
Old Oct 8, 2011 | 11:44 AM
It's a little awkward but nothing too difficult.
The valve lives down at the bottom of the radiator on the left side if you are at the front of the car.
Old Oct 8, 2011 | 12:30 PM
Thanks for the iformation
Old Oct 9, 2011 | 03:42 AM
A bit more news that dont sound good....
My oil filler cap smells of petrol????? i,m pretty sure i know what that means
sadepol01
16
Nov 22, 2024 05:05 PM
Johnken
Oct 2, 2015 10:12 AM
dpappyp
Sep 29, 2015 01:28 PM
zigzewel
Sep 29, 2015 12:42 PM
