S-Type windows and sunroof - all controls won't work
Old Jun 12, 2018 | 06:57 PM
xxphat's Avatar
Default S-Type windows and sunroof - all controls won't work
Hi guys
I am have a sudden issue with my 2003 s type. I had the car idling with all four windows down. ( sunroof closed) I opened the door to get out and move my other car. I got back in and none of the windows are functional. None of any door controls work to bring the windows up or down. the sunroof also will now not work. However, the global close and open works for everything. I havent tried anything yet. Any ideas?
Old Jun 13, 2018 | 04:56 AM
Welcome to the forum xxphat,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Jun 13, 2018 | 05:55 AM
Datsports's Avatar
Id start by making sure your battery is charged and in good condition . Then try a hard reboot , here
https://www.jaguarforums.com/forum/s...d-reset-39172/
And worst case could be a broken wire/s to your drivers door module . In the door shut area .
Old Jun 13, 2018 | 07:07 AM
aholbro1's Avatar
I seem to recall global open/close also being non-functional when I had the broken wire, but here you go in case you need it:
https://www.jaguarforums.com/forum/s...allenge-98225/
Old Jun 14, 2018 | 06:05 PM
xxphat's Avatar
Hi guys thanks for responding. I tried doing a hard reset today and still nothing. I then tried global and the windows and sunroof opened. I then tried global close and now only the sunroof closes. I tried wiggling the wires through the jam and still nothing. Ive checked window fuses and a few others for drivers side control and still nothing. I have the battery on a charger now i hope that does something. Where do i go from here.
Old Jun 15, 2018 | 04:46 AM
M-e-l-l-o-w's Avatar
I could be wrong, and it is just a thought, but I think this fault could be down to a faulty switch. I think if one of the window switched is effectively stuck down (on) then the system will time out and start doing strange things.
Try turning the rear window buttons off and check all the switches for positive operation.
Another culprit could be an after-market alarm/immobiliser system. But why anyone would fit one to an S-Type I do not know.
Old Jun 15, 2018 | 07:36 AM
xxphat's Avatar
Default Update
Ok.here is an update. I tried a hard reset and now global up does not work. Global down worked once and now all windows are down and won't come back up. Prior to hard reset global up and down worked. Now sunroof still works with global open and close but now all windows are stuck down. Thoughts??
Old Jun 15, 2018 | 06:18 PM
NBCat's Avatar
Refer to the attached electrical guide on page 29 and Figure 14.1 for the circuit layout.
It's possible the Driver Door Control Module has failed.
File Type: pdf
Old Jun 15, 2018 | 09:37 PM
xxphat's Avatar
That will not help me as I have no idea about testing working and all that
Old Jun 15, 2018 | 09:39 PM
xxphat's Avatar
Ok but then why would global work open and close before hard reset and now windows are stuck down.. if it was a break in the wire a hard reset shouldn't change that
Old Jun 15, 2018 | 10:16 PM
NBCat's Avatar
Take the vehicle to a Jaguar specialist to have the problem diagnosed correctly.
If the module has possibly failed, there is no other way to correct the condition.
heyeugenio
Apr 21, 2017 09:00 AM
RFXJ12
Nov 8, 2015 02:11 PM
JimMLiny
Nov 6, 2015 08:40 PM
RFXJ12
Oct 18, 2015 04:43 PM
cjdaniel316
May 3, 2012 04:18 PM
