Sea Foam
Old Sep 6, 2016 | 03:51 PM
Johnny V's Avatar
Default Sea Foam
Just a friendly reminder be cautious of the Sea Foam for your air intake. Did it's job, on my spark plugs not too happy to remove my upper intake and cleaning my plugs. Anyways I still use from time to time during some maintenance.
Old Sep 6, 2016 | 04:02 PM
Mikey's Avatar
Pardon my french, but why on earth would you put a product intended for WWII era two stroke outboards in a modern fuel injected car engine?
Old Sep 6, 2016 | 09:55 PM
Warspite's Avatar
Snake oil...regardless of language. Thou shalt not.
Old Sep 11, 2016 | 08:30 AM
Johnny V's Avatar
Very entertaining that is what I thought
Old Sep 11, 2016 | 08:57 AM
JagV8's Avatar
Strikes me as tricky photography. Avoid that junk.
Old Sep 11, 2016 | 03:10 PM
Mikey's Avatar
The tailpipe smoke is the product itself (50% petroleum oil, 25% naptha, 25% rubbing alcohol) burning in the engine.
The tiny amount of carbon on the pistons wouldn't be enough to cause any poor running or increased fuel consumption. If anything, it would raise compression slighty and increase engine power.
The before/after shots show insignificant change. The difference can be achieved through the old mechanics trick of sucking an equal amount of water through the engine.
Save your money.
The product does work well for it's intended purpose which was removing gummy deposits from early 2-stroke carbs. Carbs, 2 strokes and their oils have come along way so Seafom is not used for those anymore either.
Old Sep 11, 2016 | 06:47 PM
car5car's Avatar
Why did you remove intake manifold? I don't use Sea foam because it is expensive. I use Marvel Mistery oil.
Old Sep 11, 2016 | 07:24 PM
Mikey's Avatar
Why? Modern engines do NOT need or benefit from any sort of additive beyond what's already in the fuel or oil.
Please.....
dsnyder586
Apr 15, 2016 04:47 PM
skanoski
Jan 6, 2008 07:14 PM
texasjag79
May 25, 2007 05:42 PM
texasjag79
May 16, 2007 10:19 PM
