Service at 100,000 km
Old Oct 10, 2013 | 08:44 AM
Tim1988's Avatar
Default Service at 100,000 km
Hi,
My 2006 s type will cross over to 100,000 km soon. want to get a check up done. Here in Dubai where im living there are a lot of rip offs so im confused whether to get one of their "140 point check up" and pay a gazillion dollars or get a select number of checks done.
Any suggestions?
Im thinking of getting the oil, brakes and the battery checked.
Old Oct 10, 2013 | 09:42 AM
Mikey's Avatar
There's nothing really different or spectacular that happens at 100K. It's a routiine B check as shown on the mtce. schedule in JTIS, plus a fuel filter.
Old Oct 10, 2013 | 11:34 AM
JagV8's Avatar
I think you'll qualify as an arduous environment so have your own schedule - do you DIY and if so do you have the schedule?
Old Oct 10, 2013 | 11:50 AM
tbird6's Avatar
If you plan to keep the car don't do any inspections. Do proper maintenance!
Change the transmission fluid and filter, Replace the rear end oil, Replace the P/S fluid, Replace the coolant.
If you don't plan to keep the car just keep driving and sell it. Most people do this.
Old Oct 10, 2013 | 03:35 PM
Mikey's Avatar
Kinda early for the tranny fluid- not really due to 160,000 KM.
Coolant should have been done in 2011 (every 5 years or 150,000 miles)
Old Oct 10, 2013 | 04:04 PM
tbird6's Avatar
Well ZF has a different answer than Jaguar for this!
80K to 120K in Km. Please see attached ZF service document.
File Type: pdf
Old Oct 10, 2013 | 06:44 PM
plums's Avatar
The advertised life expectancy of long life coolant fills such as Dexcool only applies to the factory fill. Thereafter, it is half or so.
According to the manufacturers.
A sensible line of reasoning would be that the factory fill is under vacuum in a dry system. A flush and fill is done under different conditions, not the least of which is the fact that the system remains somewhat contaminated with the old fill. Some mechanics are now using vacuum lift systems, but not all.
BTW, for Dubai the air filter is a must service item.
And yes, the severe service schedule most probably applies.
In fact the severe service schedule applies to most vehicles if one reads the manufacturer definition of what constitutes severe service.
St.Regis
Oct 4, 2024 12:07 PM
1100me
Jul 24, 2023 06:10 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
kiddhan625
Sep 25, 2015 12:04 PM
Quebecjag
Sep 10, 2015 06:06 AM
