Side View Mirror Backing Question?
Old Oct 2, 2017 | 12:11 AM
jazzwineman's Avatar
Default Side View Mirror Backing Question?
How does one get the color backing off the side view mirror? I have readthat it snaps off, but one diagram also showed what appeared to be a screw in the middle of it.
The upper bolt rod on the side view mirror (pass. side) just disintegrated and separated the bolt from the assembly (go figure)! I can get plenty of them off Ebay that are not my red color and it appears that the red colored backing is supposed to pop off. That way I can get any color and just put on my red backing and be in like "Flint". I hate forcing things and after tying with several spudgers, but got no moment. So instead of tearing it up= what is the secret?
Tom in Dallas/Plano
05 S-Type 3.0
Old Oct 2, 2017 | 12:51 AM
JagV8's Avatar
If by backing you mean the curved plastic back that covers all the works, it just levers/snaps off. Mine felt like it would break but didn't. No screws.
There's no separate backing to it. It's a piece of curved plastic, akin to the bumper.
Old Oct 2, 2017 | 08:44 AM
So I am not confused, I have attached a photo with a yellow line around the piece I am talking about. Did you pull from a certain direction or press in on a certain area or just get a grip ( a little harder as it is smooth material) somewhere on it and just pull straight out or at an angle or do a wiggle type pull motion?
Tom
Attached Thumbnails Side View Mirror Backing Question?-resized_20171002_083531.jpg
Old Oct 2, 2017 | 10:06 AM
clubairth1's Avatar
Community Influencer
Correct that part snaps off. Yes it's held on pretty tightly and I also was concerned I would break it.
But it did pop off.
Old Oct 2, 2017 | 11:20 AM
But it did pop off.
So did you push in on the sides or top when removing or just straight pull it off with brute force?
Tom
Old Oct 2, 2017 | 01:30 PM
clubairth1's Avatar
Start at a seam and insert your pry stick.
When I work with plastic like interior door panels I use plastic pry sticks. Harbor Freight has some cheap ones. That way when I pry it has less chance of damaging paint.
Here is my favorite tool. It's used by glass shops when installing windshield's. They call it a "Windshield Stick".
htthttps://www.kent-automotive.com/K.../P90150.kap://
Looks like this;
I have several and get one started then use another one to help it along. Just takes some playing around but it's not too hard.
This is from the JEPC which is free on this forum? You might find it useful?
Old Oct 2, 2017 | 03:58 PM
Looks like this;
Thanks. I had seen the JEPC and have some plastic spudgers (that are about the same thing that I was attempting to use and then backed off as I thought I was applying to much pressure- but I do understand the scene.
Tom
Old Oct 2, 2017 | 04:40 PM
joycesjag's Avatar
Hey Tom, if you would please take a couple of pictures of removal and post to a new thread, that would be awesome!
Rick in S.C.
Old Oct 2, 2017 | 05:11 PM
Rick in S.C.
You assume success- thanks for the faith.
Tom
