Silly question - how to pull away in an auto
Old Nov 12, 2007 | 09:17 AM
rivs's Avatar
Default Silly question - how to pull away in an auto
OK I am prepared to be ridiculed but got only my 2nd auto and it is very noticable that when you pull away it is a bit sluggish for the 1st 6 feet or so. This makes pulling out of a junction a bit exciting. So as I have the expertise of the auto loving Americans here, what is the best method for a rapid pull away. I have been told (by an American) that the best approach is to hold it on the brake with my left foot and give it a bit of throttle before stepping of the brake. Is this my best bet?
cheers
Darren
Old Nov 12, 2007 | 03:12 PM
sbxt's Avatar
Default RE: Silly question - how to pull away in an auto
In an auto, to increase the accelleration you would want to hold the brake while giving it gas. Give it gas until just before the car starts to move. When it is time to go, let off the brake quickly. This will launch you at the highest rpms in an auto (well, unless you go the route of the neutral drop but I wouldn't recommend that). You also have the downfall of the auto picking your shift points, which can be overcome by manually shifting the tranny with the j-gate (basically you can ride the gears out to a higher rpm).
That will increase your take off, but you will never be able to get to the point of even being close to matching a manual gearbox. The only route that would match it (and actually surpass it) would be to install a high stall torque converter and change the shift points to their ideal settings for maximum performance through a tune. That is going a bit extreme for what your goals are though.
Also, I wouldn't use this route on a regular basis, as it will create stress on both your motor and brakes.
***Edit: And don't lie.... you know you are going to use this information to race. lol
Old Nov 12, 2007 | 10:24 PM
cosworth's Avatar
There shouldn't be any hesitation. You running crap gas/petrol in that car?
I will let you in on a secret, left foot braking in the slushbox car is the way to go.
Old Nov 13, 2007 | 05:59 AM
rivs's Avatar
cheers sbxt.
Cosworth car is a diesel so this will emphasise the initial slow pull away, as it would in a manual diesel as well.
My wife tends to left foot brake quite a bit. She did not even realise she was doing it. But think that will take a bit more time before I do it after 23 years of driving manuals.
Old Nov 13, 2007 | 10:05 AM
sbxt's Avatar
I know what you mean! My left foot is useless for braking... I am so accustomed to using a clutch (pushing all the way in) that when I try to brake with my left foot I end up emergency stopping, hahhahaha!
Old Nov 13, 2007 | 12:16 PM
cosworth's Avatar
Even as a diesel, you should not have any hesitation.
BUT - what you are feeling is turbo lag. Normal. I have a turbo car that makes abotu 400bhp and it has some lag, but anyone that complains about turbo lag AT SPEED doesn't know how to drive. From a dead stop? It's ok.
Left foot braking - handy for emergency braking, inducing understeer when needed etc. BUT - keep your foot off the brake of course while driving normally.
http://en.wikipedia.org/wiki/Left-foot_braking
Old Nov 14, 2007 | 09:50 AM
sbxt's Avatar
ORIGINAL: cosworth
Ahhh, I didn't realize that he had a turbo. Yes, you could definitely be experiencing lag. Unfortunately, there isn't too much you can do about that - but on a stock setup there shouldn't be too much lag anyways.
Old Nov 14, 2007 | 12:47 PM
cosworth's Avatar
Exactly. It's twin turbo diesel. One very small turbo for low end and a larger one that takes over on higher load.
There really shouldn't be much lag, but it's a subjective thing. You may find a weak wastegate on the primary (smaller) turbo that doesn't trip a code (yet). This is most likely NOT what you're feeling but a statistically probable cause.
Old Nov 15, 2007 | 03:58 AM
rivs's Avatar
am sure the car does nto have a fault. It is just that a dsl auto will not pull away initially as quick and a manual petrol.
Old Nov 15, 2007 | 10:15 AM
sbxt's Avatar
Ya, you may just be experiencing the slushbox buyer's remorse. It happens to me with every automatic I own.
Old Nov 15, 2007 | 12:04 PM
cosworth's Avatar
Maybe stick it in "sport" for good. I assume the diesel has sport mode...
Old Nov 19, 2007 | 01:26 PM
dervdave's Avatar
ORIGINAL: cosworth
The BMW 535d has this set up, the Jags 2.7 turbos are both the same size
Old Nov 19, 2007 | 06:13 PM
cosworth's Avatar
Same size externally but they have different A/R rarios.
Old Nov 20, 2007 | 05:51 AM
dervdave's Avatar
ORIGINAL: cosworth
Expand please ?
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
GordoCatCar
Jan 2, 2017 01:10 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
pnwrs2000
Sep 3, 2015 11:55 AM
