smell from cabin heater
Old Jan 22, 2009 | 05:00 AM
morjags's Avatar
Default RE: smell from cabin heater
cheak wireing to the fan motor ,may be loose or fan motor on its way out
Old Jan 26, 2009 | 11:17 PM
polisak's Avatar
I thought I had the same problem but took it to the dealer and found that the PCV hose had worn through and the oil was dripping on the manifold. It was happening when I turned the heat on or when I came to a stop. They figured that the PCV oil separator was gone on it too so I had it replaced. They had to take the intakes off and the lower ones too.
Old Feb 26, 2009 | 09:20 AM
MySType's Avatar
I am having the same thing on mine, when I stop at a light there is smoke that comes from the right side. I look at it and it looks as thought there is oil that is dripping on the manifold. I will have it looked at when I get my lurch fixed.
Old Jan 8, 2010 | 01:07 PM
FunJag's Avatar
Hey guys any word on the fix for the described problem of the smoke? Mine has started that mess too. Please respond with some ideas as it is scaring the mess out of my wife....(me too) Thanks.
Old Jan 8, 2010 | 06:48 PM
ndy4eva's Avatar
Please read this thread. https://www.jaguarforums.com/forum/s...ad.php?t=30535
I had oil leak that came down to manifold and burt the oil. The smell was pretty bad. I fixed it myself by replacing two IMT O-rings. It's been okay for while. I need to monitor the oil level to see any more leakage.
Oh, I have pictures after I cleaned IMT and manifold. My manifold was covered with burnt oil.
Old Jan 8, 2010 | 08:48 PM
Pantomath's Avatar
My 03' has been getting this same problem, a burning plastic smell comming out of the front heaters when I turn the heat on.
ndy4eva, how much were the IMT O-rings?
Old Jan 8, 2010 | 09:21 PM
joycesjag's Avatar
The O rings are less than $5.00 ea. you will need two. If you want to save alot of money, there is a simple way of changing them.
Old Jan 8, 2010 | 10:59 PM
ndy4eva's Avatar
Yes, Joycesjag is correct. I paid total of $10~12 cdn for two. It's green o-rings. It does take some time to change them. Oh yeah, I broke one clip that holds wipers. Just push them down to un-lock it and you can pull them out. It's bit of work but it's something you can do.
Good luck!
NathanDD6
Oct 6, 2015 11:20 AM
mat32essex
Oct 3, 2015 04:12 PM
inactualis
Oct 2, 2015 11:13 AM
rgp
Oct 1, 2015 02:55 AM
