Steering wheel moves by itself
Old May 12, 2024 | 09:30 AM
PeterPitelius's Avatar
Default Steering wheel moves by itself
Hello everyone, I'm new in the forum ad enthusiastic new owner of S-Type V6 3L 2000y / 135k km. Everything seems okay. Only one problem: when opening the car with the remote control, the steering wheel moves by itself, lifts up and back in. I also noticed that the seat and steering memory does not work perfectly. What could be the cause of this problem? Thank you for your help.
Old May 12, 2024 | 11:47 AM
motorcarman's Avatar
Turn the AUTO switch on the column to OFF!!!!!!!
Old May 12, 2024 | 12:09 PM
Thank's a lot motorcarman for your suggestion.The fact is that the switch on the column is already on OFF.... The steering wheel moves with "random" movements ...
Old May 12, 2024 | 03:22 PM
User 42324's Avatar
Have you tried re-saving your preferred steering wheel/seat/wing mirror settings ?
Old May 12, 2024 | 11:11 PM
Rober2's Avatar
turn it back to 'on', set your preferred seat and steering setting, press the 'memory' button till it lights up, and choose the 1 or 2 button. I think that's the sequence.
Old May 16, 2024 | 12:40 PM
Yes, but the problem is still there.
Old May 16, 2024 | 12:41 PM
Thank's for the suggestion. Done: the problem is still there.
Old May 17, 2024 | 07:20 AM
JagV8's Avatar
Start checking wiring, especially from the Auto switch you say is off - right back to the module.
The workshop manual & electrical guide will be invaluable.
Old May 20, 2024 | 11:43 AM
Unhappy
Thank's JagV8. All the wiring seems OK. But there is one new thing: now it seems that the seat (driver) also moves (back, slightly) when I use the remote control. On the other hand, I noticed a high oddity: when I open and close the door with the key (not with the remote control) the steering wheel and the seat do not move. What is happening to my Jag?
Old May 20, 2024 | 01:54 PM
JagV8's Avatar
The key & fobs (car came with 2) are different. Inevitably all keys are cut the same (ignore valet) whereas each fob can have its own settings.
Wayne Lea
Jan 15, 2022 06:14 AM
general_piffle
Dec 18, 2021 10:59 AM
carzaddict
Aug 24, 2016 03:35 PM
xkrdave
May 11, 2016 02:23 PM
May 26, 2007 03:41 AM
