Still have shakey wheel when pressing on brakes.
Old Oct 30, 2013 | 07:07 PM
daboss085's Avatar
Default Still have shakey wheel when pressing on brakes.
So today I had brand new front rotors and pads installed for the second time, and once again when I apply the brakes the wheel shakes. The brakes I purchased are power stop drilled/slotted rotors, and the pads are power stop ceramic. This is the second time this has happend. I dont know if the Rotors are defective? I purchased them from the powerstop website. I had them sitting for a few months in storage before I used them. I am thinking of going with just standard rotors and pads from a autoparts store. Can anyone recommend any? thanks.
Old Oct 30, 2013 | 07:59 PM
Ingo's Avatar
I recently replaced my front rotors as well, same issue, shaky wheel whenever braking. I bought R1 concepts drilled rotors, have had them on for 2 days now so it still remains to be properly accessed but i now have absolutely zero shaking, perfect feel. I recommend them, they come with a one year warranty. Also make sure you are not over tightening your lug nuts when putting the wheel back on. I have read that although rarely, it can help to warp the rotors. Also tighten them evenly, bringing in all the lug nuts to fully tightened, together instead of tightening one completely then the next and so on and so forth.
Old Oct 30, 2013 | 08:13 PM
abonano's Avatar
I tried drilled/slotted rotors on my 00 S Type - hated the feel and went back to good old rotors - no issues!
Old Oct 30, 2013 | 08:24 PM
Mikey's Avatar
Measure both sides of each rotor for runout and parallelism. If you find any issues, determine root cause. How do you know you don't have a bent hub?
Old Oct 30, 2013 | 09:14 PM
daboss085's Avatar
Before I put the power stops one I had wearever rotors. They were a bit noisy but has no shake at all to them
I switched to the power stops to eliminate that noise and now not once but twice the power stop rotors shake like crazy when pressing on the brake. I wonder if it's a power stop issue? What do you guys think of Wagner rotors?
Old Oct 31, 2013 | 03:08 AM
JagV8's Avatar
+1 on runout. You need solid facts.
dsnyder586
Dec 29, 2024 07:39 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
SCMike
Sep 9, 2015 09:30 AM
tberg
Sep 7, 2015 07:32 AM
