STR brake dust
Old May 27, 2011 | 05:14 PM
OPStr's Avatar
Default STR brake dust
I'm a relatively new STR owner and seem to be accumulating lots of brake dust - far more than I've experienced in other cars, and I'm not driving it that hard. It's a 2005 I found a couple months ago with 18,000 miles (the proverbial little old lady, so I'm pretty sure SHE didn't thrash it), so the pads are "old" but have lots of life in them. Is this typical of Brembos (do they even make the pads?)? Any suggestions as to how to keep the wheels from looking disgusting after a week or so of driving? My GTI-driving son is offended by my gross wheels....
Old May 27, 2011 | 05:21 PM
joycesjag's Avatar
Either wash them like everyone else every other day..........or put ceramic pads on
Old May 27, 2011 | 05:25 PM
searanch's Avatar
RockAuto Auto Parts
AKEBONO Part #EUR592 Rear
AKEBONO Part #EUR938 Front
Cermaic Pads all in for less than $200 including shipping. I have put 20k on mine - excellent with no brake dust - nadda...
Old May 27, 2011 | 07:13 PM
phd12volt's Avatar
Originally Posted by searanch
RockAuto Auto Parts
x1000000000
Old May 27, 2011 | 09:59 PM
androulakis's Avatar
Once you get the ceramic pads, take your wheels off. Clean them like them you have never cleaned them before, then apply two coats of a good heavy paste wax. Let it harden and buff it out....
What little dust is produced by the ceramics you can take off with a hose after that.
Take care,
George
Old May 28, 2011 | 03:11 AM
phaelax's Avatar
I have EBC red stuff (ceramic) on the rear, and I think Wagners(semi-metallic) on the front. The back stays fairly clean, the front need rinsed once a week.
Old May 28, 2011 | 07:59 AM
clubairth1's Avatar
Community Influencer
Another vote here for the Akebono pads. Have them on my 2005 STR for 30K plus miles. Should have been installed at the factory!!
Old May 28, 2011 | 08:51 PM
Pushing_Tin's Avatar
I have the same pads all around and the brake dust was reduced 80-90%.
Old May 28, 2011 | 11:08 PM
Kapitan1975's Avatar
Should have gone with the Akebono (front and rear)
I recently installed EBC red (front and rear) but still has brake dust especially the front (the rear on the other hand is clean). not sure why, might have to removed and re-do the installation.
Old May 29, 2011 | 01:40 AM
I had Akebonos on my 370Z and they make about the same amount of dust as the restuff pads do.
Old May 29, 2011 | 01:42 AM
vance580's Avatar
The brakes are biased towards the front so they do a majority of the braking to the more dust on the front is probably just from that. My rears seem to dust more so I'm assuming they are metallic and my fronts are always good so I'll assume they are ceramic. I haven't replaced my pads yet so they are what the previous owner had put on.
Oh yea X1 on the Akebonos thats what I'm going to go with once my pads are due.
Old May 29, 2011 | 04:24 AM
Staatsof's Avatar
I did exactly this when I put the Akenbono pads on.
OMG what a difference. The waxing really helps too.
Take care,
George
Old May 29, 2011 | 10:41 AM
ccc's Avatar
ccc
I went from EBC red to the Akebono with the fronts going first. EBC is better then the factory pads in terms of dust but the front with Akebono was a lot cleaner then the rears with the EBC on chrome plated wheels...fronts would be shinny and the rear would be a grey mess...just to put the Akebono vs EBC into perspective. Also, the Akebono dust is much easier to clean than the EBC.
Old May 29, 2011 | 11:26 PM
ActionJackson's Avatar
Default EBC Red
I've had EBC Red for about 20K.
Takes between 1K and 2K to fully seat the pads and then the dust goes donw considerably.
Old May 30, 2011 | 07:14 AM
The Chris X's Avatar
Akebono's here too and much better in the dust reduction category. Go for it.
I use this Armor All wheel spray stuff that actually really does work to keep the dust from sticking and what does eventually stick comes off with the hose. Not a huge Armor All fan, but this aerosol stuff really does work pretty good.
Old Jan 8, 2012 | 08:18 AM
Bacardi 151's Avatar
I'll add...I got a Centric Posi-Quiet ceramic pads...They're very dusty, I had about a 20 miles total commute (zero highway, all stop and go) and there would be visible dust after 3 days...I didn't wax the rims, though...
How many miles are you guys seeing dust on the fronts with the Akebonos?
Old Jan 8, 2012 | 09:13 AM
clubairth1's Avatar
Just a comment on brake dust. If you have a STR and drive somewhat vigorous the rear wheels will get more brake dust than the fronts. With 400 Ft-Lb of torque the traction control kicks in a bunch more than you think it does. So the rear brakes get a pretty good work out even when you don't have your foot on the brake.
I first noticed this on my wife's 2003 Lincoln LS V-8. The STR has more power so it's even worse.
Old Jan 8, 2012 | 09:43 AM
V8 Str's Avatar
I concur, under spirited driving in the STR the rears dust up much worse.
Old Jan 8, 2012 | 02:44 PM
Like none dude. There is very little dust at all with Akebonos. Probably go a couple weeks without noticing much. The OEM's dusted up by the time you got to the end of you driveway.
Old Jan 13, 2012 | 02:53 AM
Bull27's Avatar
Red Stuff ceramic pads have all but eliminated the excessive brake dust the stocks gave me. Literally it is night and day. Amazing.
clubairth1
30
Sep 3, 2025 04:38 PM
H20boy
Dec 24, 2024 03:23 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
