STR Brake fluid
Old Apr 13, 2011 | 08:53 PM
Michael Star's Avatar
Default STR Brake fluid
I tried searching, but how much fluid does the STR brake system hold?
Old Apr 14, 2011 | 03:10 AM
Staatsof's Avatar
That will depend upon how worn your pads are. But really, I doubt there's a published figure for that. I don't ever remember seeing it for any car.
Get yourself 2 quarts of new fluid and it should be more than enough. When I changed my pads I also flushed the entire system and I used about a quart.
Old Apr 14, 2011 | 07:08 AM
The Chris X's Avatar
2 quarts should do it like Bob said if you are doing a flush/fill. I may even buy an extra just in case (I use/like ATE Super Blue).
I haven't found a published capacity either. Maybe jagV8 will know, he seems to have a knack for this type of info.
Old Apr 14, 2011 | 07:58 AM
Staatsof's Avatar
I didn't use super blue on the STR this time but I have on other cars because you can get the same spec. fluid in blue and clear which helps you know that you've flushed out all of the old fluid. You just alternate colors each time you flush.
Old Apr 14, 2011 | 08:38 AM
JagV8's Avatar
Sorry, I don't know - I'd go with previous suggestions. DOT 4 fluid (given as ITT Super Dot 4 in JTIS).
Old Apr 14, 2011 | 10:33 AM
I picked up 2 liters of the ATE super blue from Amazon. Any specific things I need to watch out for when I flush/fill?
Old Apr 14, 2011 | 11:06 AM
Pretty cut and dry process to my knowledge. Avoiding boogering up the bleeder valve hardware is high on the list.
I kind of use a rule of thumb - when I think I have all of the air out, I then bleed a few more times. More of then than not another bubble or two shall spit out.
Are you bleeding via the helper with a foot on the pedal /crack open method or are you using a one man bleeder or vac bleeder?
Old Apr 14, 2011 | 11:13 AM
Two man method. I've tried the vac bleeders and I can't seem to get them to work correctly for me.
Old Apr 14, 2011 | 11:37 AM
I hear ya. If you don't use brand new tube with a Mity Vac, then it's hard to get a good seal on the caliper bleeder nipple (heh...nipple).... I end up using the vac, then for good measure having a helper come out for a few good rounds of pedal pumpin to finish off the job.
So, about the only thing you need to watch out for is making sure your helper knows not to let off the pedal until you tell him/her to!
Old Apr 14, 2011 | 01:28 PM
tbird6's Avatar
If you have a STR just be careful about banging up the pretty Brembo calipers!! I have chipped mine a bit. The large tire and wheel combination is pretty heavy.
Also the Brembo's have two bleed ports and the brake fluid will lift the paint on the caliper if left for very long. So wash off the calipers after bleeding. Brake fluid is water soluble and flushes off well.
clubairth1
30
Sep 3, 2025 04:38 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
Richard_gib
Sep 12, 2015 07:08 PM
trebor12
UK & Eire
Sep 12, 2015 12:21 PM
