STR Drinking Oil
Old Jan 8, 2022 | 12:11 PM
Flappers's Avatar
Default STR Drinking Oil
Hi, I recently bought a 2002 R and topped it up with the oil recommend from Halfords. Petronas-syntium-3000-fr-5w-30-oil. IIt has drank the whole 5 litre tub in just 3 months of daily use. It will when cold, and I've only noticed it when the air is cold, pump out when accelerating hard a ploom of white smoke. I'm not sure if it's just the air or the car, I'll check the water tomorow and the oil seems clean. . I'm at a bit of a loss... I had it cleaned off underneath and ran it for an hour on a ramp and not a drop leaked. Can anyone help please?
Old Jan 8, 2022 | 12:15 PM
NBCat's Avatar
How many kilometres/miles are on the vehicle?
Is the MIL on? If so, what DTCs are stored?
Have the spark plugs been inspected and a compression test been performed?
Old Jan 10, 2022 | 05:01 AM
M-e-l-l-o-w's Avatar
You may well find that the oil is seeping through the valve stems into the combustion chambers when the engine is off.
When you first start up this will be burnt off quite quickly with white/light grey smoke.
You may well need new valve spring seat seals. To change these the heads need to come off!
The other possibility is the piston rings, but I think you would probably also get smoke when the engine is wormed up as well.
But I may be wrong?
Mellow
AT_STR
Jul 7, 2020 05:31 PM
jomo
Dec 20, 2016 07:45 AM
crp0409
Sep 2, 2013 10:21 PM
jag79
Oct 14, 2012 08:47 PM
embassured
Mar 8, 2008 08:50 AM
