Str hid
Old Apr 11, 2011 | 11:04 AM
agp22's Avatar
Default Str hid
My 2006 STR's RH front HID changed color sometime ago, and became purple-ish.
I kept driving and did not worry.
Now the light started flashing and eventually shut itself off completely.
I have searched a bit but can't seem to find any thread describing if this could be the bulb or the ballast unit.
Can anybody advise?
Old Apr 11, 2011 | 11:50 AM
achysklic's Avatar
Take your bulb out of the other light and switch them. If the other bulb works its a bad bulb. If it doesn't work it a bad ballast.
Either one can be bought on Ebay reasonable.
Old Apr 11, 2011 | 01:14 PM
agp22's Avatar
Well thank you for the troubleshooting clue.
I had not thought of that.
Is there anything particular about removing and installing the HIDs or can they be treated just like any Halogen bulb?
Old Apr 11, 2011 | 02:06 PM
achysklic's Avatar
just don't touch the bulb with your finngers, and if it is the bulb I suggest replacing both cos the colors won't match up at first.
Old Apr 12, 2011 | 05:49 AM
agp22's Avatar
Default Ever weird
Last night the HID came on again.
But as can be seen, the color is darker.
I wonder if it is the ballast then.
Old Apr 12, 2011 | 06:41 AM
joycesjag's Avatar
hmmmm switch bulbs or purchase a very expensive ballast??????????
BTW great advise achy!
Old Apr 12, 2011 | 09:19 AM
phd12volt's Avatar
you can get replacement bulbs from here: ddmtuning.com also if your good with electricity, you can adapt over to aftermarket ballasts to save some $$$$$
BTW, HI, i havent been around in a while, but alas im back
Old Apr 12, 2011 | 09:43 AM
joycesjag's Avatar
WELCOME BACK Jason!!!
The place has not been the same without you!
Ut oh I think you should go to "S Type off topic section" I see where this is gonna go.
Old Apr 12, 2011 | 11:09 AM
Brutal's Avatar
You know you have to pull the bumper to change ballast and lights
there is not enough room to do either.
Old Apr 12, 2011 | 11:23 AM
agp22's Avatar
Pull the bumper?
Wow, no, I didn't know that.
Even just for the bulbs?
Old Apr 12, 2011 | 11:36 AM
Brutal's Avatar
Yes there is not ebough room behind hid assemblies to get them out without pulling the covver. But that doesnt take long, definitly longer than halogens though which you can get out from the back
Old Apr 12, 2011 | 11:39 AM
agp22's Avatar
Are there on-line instructions on how to actually pull the bumper and put it back?
Old Apr 12, 2011 | 01:07 PM
phd12volt's Avatar
thanks. lol. ok fill me in???? whats going to happen?? wait we have an stype off topic now??
Old Apr 12, 2011 | 01:27 PM
vance580's Avatar
https://www.jaguarforums.com/forum/s...-w-pics-28534/
Doesnt take long at all. This is for a non R but they are bolted up the same(post is actually courteously provided by joycesjag). Now that you know where all the bolts are should take 10-15 min tops.
Old Apr 12, 2011 | 02:13 PM
agp22's Avatar
Thanks to all of you. I had looked it up and that same post came up.
I guess I'll try switching the bulbs and drive a bit to see if the right side bulb goes crazy again. That should determine.
Be back soon
Old Apr 16, 2011 | 06:12 PM
agp22's Avatar
Well having switched bulbs I can advise that the problem migrated to the left side, so this must definitely be a bulb.
Thanks to all.
Old Jun 16, 2012 | 09:38 PM
agp22's Avatar
Default NEWS on HID
Hi everyone
The HIDs I had purchased in ebay, real cheap (no brand), turned out to be harmful to the ballast units.
I ended up with a bad ballast needing replacement, and also had to purchase some known brand HIDs.
Old Jun 17, 2012 | 01:52 AM
jag79's Avatar
Hi everyone
Dang after more than a year you report back? lolz... But hey you should have bought the ballast from ddmtuning. I changed out my fog lamps to HID using there kits. Hope it works for you now with the new ones.
Old Jun 17, 2012 | 12:07 PM
agp22's Avatar
Just sharing the knowledge...
Old Jun 17, 2012 | 12:21 PM
Better lat than never!
clubairth1
30
Sep 3, 2025 04:38 PM
Manjag
Oct 1, 2015 05:34 PM
JaguarSV8
Oct 1, 2015 01:58 AM
SoCalJagS
Sep 27, 2015 09:20 AM
