Str,po332 bank 2 knock sensor low input
Old Sep 10, 2011 | 06:14 PM
carlorner's Avatar
Default Str,po332 bank 2 knock sensor low input
Keep getting code p0332 and restricted performance, the second I clear code it immediately returns.. Wtf!! I guess it has to go to dealer.. Sensor is cheap but supercharger needs to be remove to get to it. They said $1200 .. What should I do?
Old Sep 10, 2011 | 08:08 PM
BlackX300VDP's Avatar
Yeah, thats surely a bad sensor. Sometimes you can limp it along by staying out of the go pedal. It is not cheap to get that supercharger off. Give me a shout if you want to bring it down to Wilmington to fix it.
Old Sep 11, 2011 | 03:41 AM
wcabro's Avatar
Just a suggestion. When was the last time that the fuel filter was replaced. Lack of fuel can also cause these errors.
Ciao William
Old Sep 11, 2011 | 04:28 PM
carlorner's Avatar
So this morning no code, no restricted performance. This car is parked outside and not driven daily, but once or twice a week, it seems to always act up the day after it stops raining...
Old Sep 11, 2011 | 04:56 PM
JagV8's Avatar
There's a TSB for water getting in to the KS (knock sensor) - but it's for the V6 3.0 car.
S303-24 "V6 Engine MIL Lamp On/DTC P0332 - Water Entry In Knock Sensor Connector - Install Sealing Patch"
I think it'll be in the TSB section, in case it helps.
clubairth1
30
Sep 3, 2025 04:38 PM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
Sep 6, 2015 06:51 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
