STR Torque Converter P0741
Old Jun 20, 2011 | 11:19 AM
searanch's Avatar
Default STR Torque Converter P0741
I had the sleeve connector replaced about a month ago. The transmission works flawlessly with the exception of throwing this fault code when climbing a hill at low rpm in fifth or sixth gear with a slight depression of the accelerator.
Do I need a new torque converter? Where is the best/cheapest place to get a new torque converter or even better a quality rebuild?
Should I be looking at something else besides a tc replacement? It would appear that others have had this problem and what was the solution.
I am aware of TSB 307-15 faulty lining TC specific to 03 STR
I am aware of P0741 TCC stuck open
Old Jun 20, 2011 | 01:00 PM
JagV8's Avatar
I'd think either S307-04 v2 or S303-13 v3
Neither look good.
Old Jun 21, 2011 | 09:33 AM
phd12volt's Avatar
i had to have my torque converter replaced. It took them 3 weeks to do it, and after all was said and done about 3grand.(warranty covered the repair and labor, but not the fluid)
Old Jun 23, 2011 | 01:37 PM
searanch's Avatar
Neither look good.
I have searched to no avail to discover what the above TSB contain. Appreciate a link or any other form of information...
Old Jun 23, 2011 | 02:36 PM
Brutal's Avatar
Theres info from zf that this can also be fixed with a new software update and adaptations cleared to the trans, along with the gearload faults. Jaguar wants this done first before any parts replacements
Old Jun 23, 2011 | 04:20 PM
xjrguy's Avatar
Attached are some bulletins that explain some ground work to do before condemning the torque converter. I'd bet that's where you'll end up though.
Here is a link to a post where we covered the issue pretty well.
https://www.jaguarforums.com/forum/x...57/#post347006
Cheers,
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 24, 2011 | 10:23 AM
JagV8's Avatar
Sorry for the delay - I was out.
I goofed, too
The first does not apply to an STR (or any redesign car 2003-on).
Also, I meant S307-13 not S303-13. It's the one that does call for a new TC and is:
File Type: pdf
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Jagfastic
Sep 14, 2015 07:41 PM
rachelstr
Sep 3, 2015 12:59 PM
