Stripped screw on thermostat
Old Nov 2, 2015 | 03:03 PM
jaggirl75's Avatar
Default Stripped screw on thermostat
Trying to replace my thermostat and apparently the bottom screw stripped. What are the options to get it out?
Old Nov 2, 2015 | 03:08 PM
WhiteXKR's Avatar
Can you post a cellphone picture? That would help us give you the most useful advice.
Old Nov 2, 2015 | 03:30 PM
Cambo's Avatar
This sounds familiar https://www.jaguarforums.com/forum/x...warned-105468/
Old Nov 3, 2015 | 04:51 PM
tbird6's Avatar
No car, No motor, No answer.
Old Nov 4, 2015 | 08:24 AM
aholbro1's Avatar
2003 STR per JagGirl's member profile page.
I don't know if the V-8 practiced the same affront to common sense as the V-6, selling you a new thermostat complete-in-housing when you needed an upper rad hose because the silly little turret broke, but if so, you should be able to find plenty of low-cost or free t-stat housings by just asking....I think I may have two for the 3.0L lying around the shop somewhere.....
Old Nov 4, 2015 | 08:33 AM
Brutal's Avatar
threads stripped or head rounded off? big difference in issue. And Its a metal cross over pipe on the STR SC V8. but the little 8mm bolt heads do tend to round off which is why I use snap on 6 points on them. others tend to open too much and round a frozen bolt since steel and aluminum really tend to like each other much over time and seize
Old Nov 4, 2015 | 08:30 PM
motorcarman's Avatar
Maybe the car is X200 4.0 and the brass insert in the resin housing is SPINNING?????????????????????
bob gauff
jaguarxjl
Apr 21, 2025 08:18 AM
trulycar
Nov 3, 2015 09:45 PM
ttstanescu
Oct 31, 2015 09:58 AM
SD96XJ6L
Oct 30, 2015 10:15 AM
Topsales1
Oct 30, 2015 02:39 AM
