Stuck in Park...Please Help
Old Jul 23, 2013 | 10:49 PM
tonydrea727's Avatar
Question Stuck in Park...Please Help
My wife informed me that as she was backing into a parking space our S-Type stopped moving back, even though it was still in reverse. She said that she put the car in park in an attempt to immediately put back into reverse and continue backing up. The car did go into park but would not come back out of park. When I got home to check it I couldn't move the lever at all. Neutral is lit up in red, even though the car is in park. There are no error messages or warning lights on the dash. Oddly enough when I attempted to use the memory seat function to move the driver seat back nothing happened. What in the world is going on?
Old Jul 24, 2013 | 01:14 AM
JagV8's Avatar
Car details?
Multiple threads on here with answers but the kind of autobox you have matters.
Old Jul 24, 2013 | 01:20 AM
thebiglad's Avatar
You have the ZF HP26 gearbox and one of the few known issues with this 'box is that the bracket on the side of the box that holds the selector cable comes undone.
From memory it's on the LHS of the gearbox and is held in place by 2x 10mm (I think) bolts, which come undone periodically. This makes gear selection somewhat random.
To check get underneath the car and look on the LHS of the 'box, identify the cable and the bracket and tighten as necessary.
Old Jul 24, 2013 | 04:13 AM
JagV8's Avatar
Er, how do you know it's the ZF?
It could be a failing battery.
If the 5R55N it can be the shifter cable, or other faults.
In all cases - Search using
stuck in park
should help.
Old Jul 24, 2013 | 04:20 AM
jimbov8's Avatar
+1 on Jagv8's comments.
Fully charge the battery first, while this is happening the car will have chance to reset itself. Reconnect and try again.
Old Jul 24, 2013 | 06:44 AM
sjgh's Avatar
- for all its worth here's a video of someone showing and the tightening the two bolts on a S-type R - around 2:00 min's in he shows the two bolts that need to be tightened talks abut being stuck in park.
Old Jul 24, 2013 | 05:22 PM
tbird6's Avatar
Be sure and look under the car for any stray bolts. Since it happened that quick one of the bolts might have just fallen out. Several people have had them come completely out. I used a dab of blue Loctite on mine. They are small 8mm bolts so tighten GENTLY! Snug is good enough.
Old Jul 25, 2013 | 05:20 AM
thebiglad's Avatar
stuck in park
should help.
Er, because in his siggy Tony says it's a 2005 3.0.
Old Jul 25, 2013 | 05:22 AM
JagV8's Avatar
I don't see any signature
Oh great, what weird thing's happened to my browser (or something else, forum setting?, what?)....
Old Jul 25, 2013 | 06:56 AM
police666's Avatar
I see his sig
Old Jul 26, 2013 | 11:33 AM
JagV8's Avatar
Thanks - turns out it was ABP (Ad-block plus).
Marque
Oct 11, 2015 05:59 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Ragn0r
Sep 29, 2015 10:38 AM
