Stype R transmission issue
Old May 18, 2018 | 10:53 AM
dsnyder586's Avatar
Default Stype R transmission issue
I have a 2003 Stype R and here are the symptoms:
1. when at a stop (ocasionally) the TC seems to unlock and if I press on the accelerator it does not go for a few seconds.
2. When giving it over 1/3 throttle it will slip occasionally
Any ideas? If it were mechanical I would expect it to be consistent, but it is not-
sometimes it drives just fine, other times slipping- weather and temp do not seem to be a factor. Have tried both sport and non sport mode as well as traction control off and on same results.
I am hoping someone has had the same issue and can shed light. I do have a spare trans if I need to replace but would prefer not to have to go through all that.
Old May 18, 2018 | 12:21 PM
Jon89's Avatar
Have you done a drain-and-fill of your ATF? If so, what ATF did you use? Are you positive that your ATF is currently at the proper fill level?
Old May 19, 2018 | 06:11 AM
JagV8's Avatar
Start with fuel trims via OBD and also check for any pending codes.
Any engine issue can upset the trans.
Also be sure your battery is not tired or flat as that upsets anything rather randomly.
kaotikd
Jul 9, 2017 03:37 PM
93xj6
Jan 3, 2016 07:43 PM
worker91
Apr 28, 2013 04:43 PM
Sixx Dogg
Jun 7, 2011 05:34 PM
FloridaJag
Nov 18, 2009 11:10 AM
