supercharger belt replacement
Old Jan 17, 2011 | 10:42 AM
harley47's Avatar
Default supercharger belt replacement
Help, I need a source for a replacement supercharger belt for my 03 jaguar s-type R. Jaguar has changed the belt design and will not sell the old-style belt any longer. They want you to replace the belt with a double sided one, and buy a new bracket, a new tensioner, and a new idler. Around 400 bucks. Any help would be appreciated.
Old Jan 17, 2011 | 11:09 AM
uropnm6's Avatar
Harley I got one from amazon for around $26 Goodyear Gatorback 4080515 hope this helps.
Old Jan 17, 2011 | 11:32 AM
avos's Avatar
That size is for a 4.0 engine, you need 1 size up, like the gates K080525
Old Jan 17, 2011 | 11:37 AM
WhiteXKR's Avatar
Goodyear Gatorback 4080525 will work for the 4.2 too, also on Amazon.
Old Jan 17, 2011 | 03:36 PM
Riski's Avatar
AVOS, you know what the size might be for the 3lb upper pulley? I cant find my last on I put on....
Old Jan 17, 2011 | 03:48 PM
avos's Avatar
What is the diameter?
Old Jan 17, 2011 | 03:54 PM
Riski's Avatar
Ill get back to you on that....It was from pheonix coach works
Old Jan 17, 2011 | 04:03 PM
WhiteXKR's Avatar
The Phoenix coachworks pulley is about 2.6" in diameter. I did not change the belt size when I installed mine.
Old Jan 17, 2011 | 05:23 PM
harley47's Avatar
I'm sure the V8 is different than the 6 cyl, so I will check out the number you suggest. But, do you really think these numbers are good for the v8 supercharged s-type?
Old Jan 17, 2011 | 05:27 PM
harley47's Avatar
Thanks, for the info. I called two jag dealers and they wouldn't tell me the old part number or how long it was so I'm at a loss as to how to insure I get the right size belt. Their too expensive to just buy and hope. I will do my best to find out how long these belts are (numbers you guys are giving me) then measure mine.
Old Jan 17, 2011 | 05:35 PM
WhiteXKR's Avatar
I do not understand your comment. The supercharged S-Type and the XKR are both V8 engines.
The 4.0 and 4.2 use different belts. With a 2003, you have a 4.2.
The XKR and the S-types both use the same supercharger belt. So a Gates K080525 or a Goodyear Gatorback 4080525 is what you need.
Old Jan 17, 2011 | 06:17 PM
clubairth1's Avatar
Community Influencer
Thanks WhiteXKR!
I wanted the Gatorback belt but had not found it. This is a double sided grooved belt like the upgraded one from Jaguar?? Not the old single sided grooved belt that has been upgraded when the pulley changes where done for the squeaking SC belt TSB?
Old Jan 17, 2011 | 07:08 PM
WhiteXKR's Avatar
No, this is the Goodyear Gatorback version of the SINGLE sided belt which works with the original idlers and tensioners. Never had any squeaking on mine.
Old Jan 17, 2011 | 09:14 PM
clubairth1's Avatar
OK. Thanks. I am still looking then for the double sided ribbed belt in the Gatorback brand. I am not sure if they ever made one?
Old Jan 18, 2011 | 01:03 AM
avos's Avatar
@Riski,
My guess would be a K080514 belt from gates, but Phoenix C. should be able to let you know the right size or?
Old Jan 18, 2011 | 06:21 AM
WhiteXKR's Avatar
Originally Posted by avos
@Riski,
On their website Phoenix calls for use of the original belt. http://www.phoenix-coachworks.co.uk/superchargers.html
As far as I can see, the only downside is the belt wear indicator gauge on the vehicle is no longer accurate.
Old Jan 18, 2011 | 05:55 PM
harley47's Avatar
Sorry, my bad, I was responding to the comment that the belt was for a 4.0 and I was thinking 3.0 when I read this as I didn't know there was a 4.0 engine. So I said mine is a 4.2 v8 and the v8 must be different than a 6 cyl ie. 4.0. I was wrong and of course I don't know all the jaguar models so I will make mistakes. I thought I read the Gatorback was a two sided type, thought it might be the new version, which I can't use at this time. I will check the 4080525 out. Again thanks for the help.
Old May 16, 2012 | 03:29 PM
jag79's Avatar
This answer still hasn't been responded to, but I too am curious to know if there is a double sided Goodyear Gatorback belt available on the market for the STR SuperCharger?
Update: Guess they don't make it according to one of the members on this link
https://www.jaguarforums.com/forum/s...49195-a-66821/
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
FeralJag
Jan 11, 2016 05:07 PM
KarimPA
Sep 3, 2015 07:32 PM
nd143
Sep 3, 2015 04:42 PM
