Surge when shifting gears....
Old Aug 27, 2013 | 10:42 PM
daboss085's Avatar
Default Surge when shifting gears....
Once in a while I feel that push from behind when I am shifting when driving, I will feel it kick into the next gear and then there will be a slight push, not major but can def be felt with paying attention. I had the transmission serviced with new fluid and filter at 90k, I have 94 on the clock right now....
Old Aug 28, 2013 | 01:04 AM
JagV8's Avatar
Is your VIN after M45254?
Old Aug 28, 2013 | 06:39 AM
daboss085's Avatar
no, it's before.... thanks.
Old Aug 28, 2013 | 07:40 AM
JagV8's Avatar
You have the Ford 5R55N box. Not a common problem but maybe low on fluid?
Make sure engine is happy (no codes) as a good way to upset an autobox is a misbehaving engine.
(The problem you mention is usually with the ZF box, so you side-stepped that!)
hkmcmast
Nov 29, 2015 06:56 AM
Johnken
Oct 2, 2015 10:12 AM
hughey
Oct 2, 2015 05:17 AM
dansxj6
Sep 28, 2015 08:02 AM
