Sway bar
Old Jun 1, 2013 | 08:57 PM
Ahiman's Avatar
Default Sway bar
So, my rear sway bar sheared inside the bushing. It must have collected moisture under the rubber because the rest of it is perfect. I have been searching for a used one, and I found a few that are off of XJ8's that say they are compatable. Can anyone confirm this? Mine is a 03 s type late VIN. I really don't want to pay $245 at the dealer.
Old Jun 1, 2013 | 09:27 PM
Tijoe's Avatar
I've read that the XJ8 rear sway bars are the same as well. Pictures I've seen of the XJ8 rear sway bars look to be the same as S-type rear sway bars. I recently measured the diameters of my 2000 S-type and 2004 STR rear Sway bars and both measured at 18.2mm. I read Jaguar forum posts, in the XJ forum, that they are 17mm.
I have a question. Can the sway bar be swapped without dropping the sub frame? I couldn't reach the bolts
I am slowly researching/working on installing a larger diameter 3-piece sway bar. I'll use a straight bar with end splines and custom bent arms. Months away at the rate I am going.
Please let me know what you find out.
Old Jun 3, 2013 | 09:40 AM
TonyX's Avatar
All things equal, having smaller size(less roll stiffness) anti roll bar at the back will give the car more benign handling characteristics.
If the XJ 17mm bar fits, it's a safe alternative to new 18.2mm bar.
Old Jun 3, 2013 | 04:31 PM
Cambo's Avatar
Check my thread in the Suspension & Handling subforum https://www.jaguarforums.com/forum/s...02-x350-94044/ short answer yes the bars are interchangeable, yes you have to drop the subframe.
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
JagBrian
Oct 1, 2015 12:52 AM
dpappyp
Sep 29, 2015 01:28 PM
