Thinking about buying a S-type soon...
Old Dec 8, 2015 | 03:44 PM
JaguarXKR's Avatar
Default Thinking about buying a S-type soon...
As the title says, what should I look out for when buying one?
I am looking at a 04-06 most likely with the 4.2L.
I am familiar with the S-type as my mom has a 2002 Ford Thunderbird (which is the same chassis and so on...).
Old Dec 8, 2015 | 05:57 PM
JagV8's Avatar
The 4.2 is great.
Think about the STR. Even better.
Old Dec 8, 2015 | 06:55 PM
Jon89's Avatar
Yep, the newer the better in most cases. Most of the S-Type's major flaws were addressed by the last three or four model years. Just keep in mind that truly well-cared-for specimens are getting more and more difficult to find....
Old Dec 9, 2015 | 07:00 AM
ZenFly's Avatar
I drove a few before buying my 06 and it was the one with the most miles. Almost all had oil leaks to some extent and I felt some clunks shifting problems in 3 I drove.. One of the most amazing things about these is the ZF6hp26 transmission that I think is in 2004 and above and is one of the upgrades mentioned .. I'm fairly new to the forum and there are guys here that have forgotten more than I know but my suggestion is drive a few.. I also found a certified Jag Tech to go over the car with complete electronic and mech check. Bottom line I've had two Mercedes and one Beemer.. This is the best car I've ever had.
Old Dec 9, 2015 | 08:55 AM
JagV8's Avatar
I think the (2002) Tbird used the 5R55N. The ZF 6HP26 is much better (and came with 2003-on S-Types in USA).
I also think the S-Type's suspension will be better - for a saloon (which my rather limited Tbird knowledge tells me a Tbird isn't!).
Go driving, you'll like 4.2 S-Types whether NA (300HP) or SC (400HP)
Old Dec 9, 2015 | 09:55 AM
Ragn0r's Avatar
Default Under the unit
If possible, when going over any unit I would get the vehicle up on a lift so you can walk around with ease doing a good inspection. Take note the condition of the catalytic bits that are equal in color. Suspension bushings and such. I would even remove the belly pan for inspection. Go over the owners manual and check all switches and controls at engine operating temperature
Old Dec 9, 2015 | 10:02 AM
Ragn0r's Avatar
Default up on a lift
2007 S-Type R (68km)
Old Dec 9, 2015 | 10:17 AM
Ragn0r's Avatar
Default rear suspension bits
2007 S-Type R (69km)
Need to replace these bushings
Old Dec 9, 2015 | 12:03 PM
ZenFly's Avatar
I have a few of these boots split but they don't seem loose at all and nothing is rattling .. I planned to wait until I heard or felt one loose before replacing them. Is that a bad plan?
Old Dec 9, 2015 | 12:18 PM
Jon89's Avatar
The risk you run with a cracked boot is that the joint it was protecting loses its lubricating grease over time, which then accelerates the deterioration of the metal-to-metal moving parts inside the joint. So even though you don't perceive any issues for awhile, that joint will eventually fail....
Ragn0r
Mar 6, 2024 07:50 PM
Rockaway naye
Jan 8, 2021 05:51 PM
jeffersonj
Jan 26, 2016 11:27 AM
Choptank
Dec 8, 2015 07:50 AM
natwal
Dec 4, 2015 11:24 AM
