trans linkage ?
Old Feb 26, 2011 | 05:53 PM
croppy's Avatar
Default trans linkage ?
i went and changed my oil today, after watching the oil change video (by vance580) in the faq section, i was going to check the shift linkage bolts but didnt see them, i have a 2000 stype with 3.0 are they in the same spot? does my car even have them? thanks in advance
-dan-
Old Feb 26, 2011 | 06:03 PM
jaguar007's Avatar
Banned
-dan-
Dan of course your car has one boy! LOlz...all cars have one unless you driving a UFO. Alright then just look under around the drivers side of the tranny its there! Search around the forums I saw it awhile back when I wasn't a member. A lot of useful things on here if you just search, ya know
Old Feb 26, 2011 | 06:05 PM
vance580's Avatar
Yours are most likely in a different location. You have a different transmission. I have never worked on the early model trans. The video is for the ZF26 trans which got switched into the Stypes in 2003. So you have the early Ford type trans not sure where the linkage is or if that is a common problem with that trans. It is common on the ZF's to come loose.
Old Feb 26, 2011 | 06:43 PM
Bodyman's Avatar
I've read about these also. Would removing them and using some blue locktight be a permanent fix?
Old Feb 26, 2011 | 07:21 PM
aholbro1's Avatar
Bodyman, I posted a pic in #16 https://www.jaguarforums.com/forum/s...smission+bolts
Yeah... you can do that...but they are easy to tighten and apparently an absolute bitter-ex-wife to remove and replace!
Dan,
Sorry dude, you are SoL for pics. There may be one on here somewhere, but I don't recall it. As Vance said, you've got a different xmsn and it mayn't even be an issue on that one...no matter, you can still worry over the park-pawl or whatever it is that devils the pre-ZF xmsn models!
Old Feb 26, 2011 | 08:06 PM
Bodyman's Avatar
Ugh, never heard that one before but completely understand. Don't ask how I know.
Johnken
Oct 2, 2015 10:12 AM
Manjag
Oct 1, 2015 05:34 PM
mrplow58
Sep 30, 2015 08:56 AM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
